WD45 3 bolt to 4 bolt front end
WD45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WD45 Quote  Post ReplyReply Direct Link To This Post Topic: WD45 3 bolt to 4 bolt front end
    Posted: 11 Jan 2018 at 7:43am
Serial number that the WD45 changed from 3 bolt front support to 4 bolt .
Fred Dunlop, G,B,CA, WC,WF, 3 WD45`s,gas, diesel and LP,U,D10 series III, D12,D14,D15 SERIES II,D17 Series IV in Gas and Diesel ,D19 GAS and D21,170 185,210 ,220 an I-600 8070 fwd, 716H and 1920H
Don(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jan 2018 at 8:40am
S/N 186413
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jan 2018 at 9:04am
But, there could have been 4 bolt front ends installed later on into tractors that were BEFORE that s/n 186413.
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jan 2018 at 3:57pm
Not long after the start of the WD-45 Diesel at 165056, apparently mostly because of the extra weight.
Edited by Gary - 11 Jan 2018 at 3:58pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote TedBuiskerN.IL. Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jan 2018 at 1:58pm
The problem with the three bolt front end is that the bolts tend to work loose.
