WD air cleaner hose
Matt Tallant View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matt Tallant Quote  Post ReplyReply Direct Link To This Post Topic: WD air cleaner hose
    Posted: 10 Jan 2018 at 6:05pm
Do they need to have the spring inside?
Alberta Phil View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alberta Phil Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jan 2018 at 6:09pm
None of mine have a spring inside.
acd17toy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote acd17toy Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jan 2018 at 7:28pm
  My WD parts book show a spring in the air cleaner hose. If using a soft hose a spring is needed to prevent the hose from being sucked together when throttles is pulled wide open.
Allis dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jan 2018 at 7:43am
My steiner replacement doesn't have a spring. It hasn't sucked in yet...
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alberta Phil Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jan 2018 at 9:24am
I would think if the hose sucks in that would indicate a restriction in the air cleaner.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jan 2018 at 9:29am
The older style hoses were SO THIN that they sucked in.  The newer ones are thicker.  Lots of the older radiator hoses had springs in them, but none of them do anymore as they made them thicker.  The older ones you could almost stick your finger through when they were hot.  Felt like much.  I haven't see one with a spring in it since,,,,,,,,,,,,,,,,,back in the 60s.
