Illinosis DOT regulations
DaveWisc. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveWisc. Quote  Post ReplyReply Direct Link To This Post Topic: Illinosis DOT regulations
    Posted: 09 Jan 2018 at 9:24am
I plan on going to the GOTO in PONTIAC,ILL.SO this is my question.I plan on taking my D21 and my A. I have a dual tandem trailer which is a 20 ton trailer.The truck is a Chevy 2500 HD which is not a dually. Is this legal in Illinosis or how do I find out ? Thanks for any help
DougS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2018 at 9:30am
What kind of weight are you talking about? It seems to me that you'll be well above the towing capacity of your truck.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveWisc. Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2018 at 9:41am
The weight of the tractors should be D21 11000 and A is 8000 so total of 19000.
old farmer View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote old farmer Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2018 at 9:42am
What does you truck and trailer weight empty? That would a good starting point, then each tractor separately which will give a starting point when talking to DOT, get results in writing with name of who you talked to
Fred in Pa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2018 at 9:56am
Dave I would guess that combo of truck and trailer are not legal in any state .
 As far as talking to someone and getting something in writing ,that will never happen .
nonetheless ,still dead.
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2018 at 9:59am
Your pulling a 40,000 trailer with a 3/4 ton pickup. If they stop you it'll be impounded even if you don't have a tractor on it.if you truck is a 2500HD your trailer is still 17,000 pounds over the max tow rating of your pickup. Your a ticket looking for someplace to happen.
Edited by Dakota Dave - 09 Jan 2018 at 10:03am
BEK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BEK Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2018 at 9:59am
Max towing capacity of the Chevy 2500 HD is 17,900 lbs.  The D21 and A will max that out not including the trailer.
BEK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BEK Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2018 at 10:10am
I think a few of us that play with the old iron have pushed some boundaries at times.  I just brought home a tractor towing through three states and may not have met each states requirements?  My bigger concern was heaven forbid I get into an accident.  If they find I'm overloaded or over weight everything could quickly become my fault regarding liability.  Good luck.
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2018 at 10:13am
right or wrong, I pull my dual wheel tandem trailer all over IL all summer with my 210 and polaris ranger on it, with my Dodge 2500 single wheel truck. Typically they don't mess with you if the rig looks nicely kept, and good chains used properly. But, I read all the time, they are cracking down on us all in search for revenue. Worst state I've heard about is Iowa.
Allis dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2018 at 10:55am
I'm guessing it's not a 20 ton trailer. He probably means 20,000lb trailer. 20k per axle is what semi-trailers are rated for.
I think legally you'd be ok. An Indiana DOT officer email me this when I asked a similar question
The only time you need to worry about the GVWR of your vehicles is if they are considered commercial motor vehicles, otherwise the only thing you need to worry about is your plate weight.
Legality aside, I have a 3/4 Dodge Hemi and a 20K gooseneck. I would not want to put more than 10K on the trailer and pull any farther than a couple miles. The truck just isn't made for it. My trailer weighs 6k, so a D21 and an A would be overweight even for the trailer. I know the truck takes some weight but still...
Edited by Allis dave - 09 Jan 2018 at 10:56am
Roger (NE) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Roger (NE) Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2018 at 11:36am
I don't really think how nice your rig looks has a lot to do with it. Case in point...neighbor recently traveled to Wisconsin to pick up a loader he had purchased. Went from southeast Nebraska across Iowa toward Wisconsin. Was just about out of northeast Iowa when stopped by DOT for excessive tint on windows and it mushroomed from there. By the time the officer was done with him there was a full page and another half page of "violations". He showed me the papers. His rig was a very late model Dodge 3500 and almost new dual tandem 30 foot trailer. About as nice, well kept pulling outfit as you would find anywhere. He just happened to run across an over aggressive individual that wanted to show his authority. All that being said, I have pulled trailers behind pickups for a lot of my almost 70 years in Iowa without any incidents whatsoever. Go figure!
ac fleet View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac fleet Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2018 at 12:22pm
Get a semi and lowboy and save yourself the grief of paying out big fines, PLUS the safety thing! thanks; ac fleet
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveWisc. Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2018 at 12:32pm
You guys are right I have two axles and the trailer is rated at 11.5 per axel so about 23000 pounds.I am going to take my D21 and B to the show tractor weight will be about 12000 pounds plus the truck and trailer. This should be legal.
cwhit View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cwhit Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2018 at 4:29pm
Remember that this will also be Labor Day weekend . In this financially screwed up state, the law enforcement will be spread pretty thin. As long as you’re moving, I really doubt that you will even get a glance. Stay away from Chicago and come on down. We’re going to have a good time.
dawntreader74 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dawntreader74 Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2018 at 4:59pm
if your trailers got a 20000 P tag on it ' an a 8000 or 12000 tag on the truck' why should anyone bother you anyway.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2018 at 5:16pm
Still wouldn't hurt to do an anonymous call (from a phone booth) and see what they say.  Tell em you're doing it in two days, from the OTHER end of the state.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2018 at 5:59pm
If your truck has a diesel, the max towing rating is 17,000. Otherwise it’s around 13,000. Even with trailer brakes you’re asking for trouble if you need to make a sudden stop or evasive maneuver.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2018 at 6:28pm
If the GCVW is over 20,000 lbs they may still go after you fer a health card, and non cdl cdl. No I didn't repeat that last cdl. Md does this, and some other states...
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2018 at 6:36pm
all it'll take is someone with a new drivers license or someone that has to much booze in them to ruin your year!
d17brown View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote d17brown Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2018 at 7:43pm
take the GVW OF THE TRUCK AND TRAILER, ADD THEM UP.YOU CANT GO OVER THAT WEIGHT. ALSO EACH AXLE IN THE PICTURE WILL HAVE TO BE WITHIN ITS LIMITS. YOU WILL NEED A CDL AND PROPER LICENSE ON THE TRUCK TO HAUL THE WEIGHT YOU TOTAL
phil
EPALLIS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote EPALLIS Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2018 at 7:49pm
Agree with CWHIT. It's Labor Day weekend and there is no money in this state to pay time and half/overtime to any officers. They'll be spread thin for emergencies only. Hope to see you there!
Calvin Schmidt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2018 at 8:15pm
I pulled my D-21 (10,300 lbs) to the Canandaigua GOTO (4 hours) with a GMC 2500 and a gooseneck trailer with 14K axles. No problems  and with all ratings of the truck, trailer, tires and plate weight. Use my semi most of the time now. Too much US truck regulation now and a super aggressive US border patrol. Just coming to Pontiac with the camper now.
Gary Burnett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2018 at 9:08pm
I don't know about counting on the cops not being around they can catch one overloaded
truck and pay their wages for the whole weekend.All the rest they catch are just icing
on the cake.
AC7060IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2018 at 9:08pm
If your rig has a GVWR of more than 8ton (16,000lbs), you're required by law to stop at all "opened" IL weigh stations. Upon entering a truck weigh station or being randomly pulled over & stopped for any DOT check point, your rig can be subjected to ALL DOT compliance - known or otherwise. That applies to any & all USA states.
Depending on the DOT officer, your DOT compliance efforts(CDL, medical card, USDOT registration, UCR, IFTA & probably very soon ELD - to name just a few...) & your willingness to cooperate during your rig inspection, will probably yield how gracious, or not, the DOT officer reacts.
You may choose an alternate route to avoid weigh stations, but DOT check points can be positioned on any road.
FYI - try to consider the fact that the DOT officers are doing their job for YOUR benefit.
In the 33 years of my CDL career, any of my disagreements during compliance checks get clarified when a DOT officer reminds me that even though he may agree with my arguing concerns, upon any incident on the road where my rig is involved & personal &/or property damage results, the insurance attorneys &/or any hired personal attorneys will stop at nothing to find anything that is not in compliance (fault) with my rig and there upon will insue compensation.
If you're like me & favor a similar notion that I'd hate to see you loose your beautiful AC D-21 and any other AC piece, let alone your entire rig too, & perhaps your house, etc, etc, etc... Please learn the DOT laws, get DOT compliant, & thank the next DOT officer that helps find anything that could have possibly resulted into a negative opportunity for you.
Edited by AC7060IL - 09 Jan 2018 at 9:11pm
Michael V (NM) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Michael V (NM) Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2018 at 9:29pm
Geez...after reading AC7060IL post,,,looks like ya jus better leave the tractor an trailer at home...
Here's my take, you are NOT commercial, ie hauling for any revenue, that makes it a hobby...and should be exempt,, but I don't know how IL or other states look at that..
Next idea, get one of them big motor homes an pull an enclosed trailer, as big as you want...no problems then...because its an RV..no weigh stations, no DOT checks....
AaronSEIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronSEIA Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jan 2018 at 5:38am
My take.  CDL is about weight.  DOT number is commercial or not.  22,000 lb tag trailer and 10,000 tag truck gets you 32,000 lbs.  That is well over the 26,000 that is needed for a class A CDL.  Tandem dual trailers are the DOTs new favorite target.  But opinions are like elbows, everyone has a couple.  Call the DOT and ask.  Get that answer in paper with that persons name on it.
AaronSEIA
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jan 2018 at 6:01am
Every state has a slightly different take on CDL.  Some exempt farmers completely from CDL requirements. I had a B when I lived in Nebraska, but no medical certificate was required as long as I was in-state.  I had an A when I lived in Oregon and I had to have a medical as any other driver would have needed.  I don't know Illinois' take on CDL requirements for farmers. The other question is: Are you a farmer or are you a hobbyist? In either case, at 23,000 pounds I think you are towing well beyond the limits of your truck.  Not a safe thing to do.
DarrylinWA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DarrylinWA Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jan 2018 at 7:03am
I have a single axle 3500 Dodge and my tandum axle trailer and and liscensed for 26,000. I am legal on all my axles and tires. I used to be at 32,000 when it was a 3 axle trailer. Left a lot of room with that weight but I carried tonnage and since I had my CDL, I was told I could carry that in WA. state where I live. I never went through and still don't go through scales and have made 2 trips to MO. and been around a lot of states like this. I am building now a 89 Peterbilt registered as a RV and that is how I brought my tractors to MO for the GOTO in my 48 ft. Kentucky trailer. I Stopped at all the scales on this trip just to see what they would do etc. I got pulled in 3 times and asked for my paperwork and since the title and registration is listed at motorhome, they sent me on my way. Side of trailer saws Private carrier and on the bottom of the door says registered RV Not for Hire. I have a bed, microwave, fridge ,portable toilet and small camping sink tucked under the bed and I am legal that way. Might want to see about doing this in future. Just what I did. Legal on all axles is #1 thing and I carry tonnage is what a local State Patrolman told me who I am friends with. Sorry for rambling. Take care and see you there this Summer at the GOTO!!!
B 10 Custom. Serial # 1001 D21, First D21 built 69 #4498 and Last D 21 Built #4609. 1946 MM UTU. And 2000, 2005 Pete's. AC custom Hauling.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jan 2018 at 7:32am
You might get to meet a EX Illinois Governor if you get the right DOT man to stop youLOL
Butch(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Butch(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jan 2018 at 7:45am
Legalities aside A person should consider what is safe. I have pulled an A around a good bit behind a 3/4 ton truck,, add a D-21 to the load? No way!  I dont care what the DOT says is legal.  Maybe its because I have had 2 near misses in the past while on the way to a show. Glad to read you decided against hauling both! It just isnt worth the risk, IMO.
