Coming soon.
alleyyooper View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote alleyyooper Quote  Post ReplyReply Direct Link To This Post Topic: Coming soon.
    Posted: 08 Jan 2018 at 7:11am
1961 D17 over haul is coming as soon as the ford 5000 is sold.
Searching the internet there at least two different kits.
One place has one as a inframe kit and another one as a over haul kit.
What is the differance besides the prices.
there sure is a huge spread in the in frame kits also.
Big smile    Al
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2018 at 7:25am
Only someone who doesn't know that type of engine would ever do an "in-frame" overhaul. It will need camshaft bearings and a rear seal to be done correctly and that means "out-of-frame".
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2018 at 8:46pm
Overhaul kit usually includes new pistons and sleeves from what I have seen.  I agree with Dr. Allis.  Definitely do the camshaft bearings while you have it apart.
dt1050 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dt1050 Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2018 at 7:24am
dito: never done a tractor engine, but have done several vehicle engines.  if the cylinder walls, bearings, etc. are worn, so is the cam bearings. and the rear seal is a no brainer, pull the engine out.  a bit more work, but atleast when it's done, it's done right.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2018 at 8:43am
Al,
 Good luck with the engine rework/rebuild on the D17.
Will be watching.
JimD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JimD Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2018 at 8:53am
Call those selling and ask them what the difference is.  Most don't know. I'll be happy to walk you through our kits and explain why I sell them.
