Craigslist
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Topic: Craigslist
    Posted: 07 Jan 2018 at 3:29pm
HD 15 on Columbia MO CL, asking 2500. The rails look sweet, 6-110? Detroit, Garwood fixed cable blade, has NOT moved nor run 12-15 years.
https://columbiamo.craigslist.org/grd/d/allis-chalmers-hd-15-bulldozer/6445111486.html
Edited by DMiller - 07 Jan 2018 at 3:33pm
LeonR2013 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LeonR2013 Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2018 at 4:24pm
For that kind of money somebody ought to be jumping on that just to keep another one going if for nothing else.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2018 at 5:40pm
looks great, price looks good too.  Somebody jump on it!Thumbs Up
Ferdinand View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ferdinand Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2018 at 5:41pm
If it would somehow jump over to NC I would buy it.
Because narrow is the gate, and narrow is the way, which leads unto life, and few there be that find it.
Mathew 7:14
Ian Beale View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ian Beale Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2018 at 7:18pm
Ought to be a 6/71 IIRC.  A neighbour has one.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2018 at 5:28am
Was wondering 71 or 110. Knew the 19 and up were 110's
acer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote acer Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2018 at 11:59am
if i had a way to load it and haul it, it would be in my back yard. its 50 miles from me
CAL(KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2018 at 12:01pm
15's are 6-71.  Hd 19's also 6-71.  HD20   6-110
pinball View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote pinball Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2018 at 12:02pm
does that machine have a shuttle valve for shifting or do you just have to shift it to forward or reverse. thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2018 at 12:07pm
shift forward and reverse on a HD15.  pattern looks like this from the seat
forward gears are         1-2    3-5    4-6
reverse directly below    R1     R2     R3
high low shifter separate
Edited by CAL(KS) - 08 Jan 2018 at 12:11pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote pinball Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2018 at 12:14pm
are you saying that if your in 1st gear there is a shift lever that will allow you to go forward or reverse without clutching. thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2018 at 12:17pm
no.  all shifts require clutching.  whether its 1 to R1 or 1 to 2.  High- low is a different shifter but still requires clutching .  forward to reverse requires clutching.    all dozers required clutching even torque converter units until the power shift transmission was introduced.   like a truck transmission just different pattern and more reverse speeds.
Edited by CAL(KS) - 08 Jan 2018 at 12:18pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote pinball Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2018 at 12:23pm
understand now. I may call the guy and go look at it. Not sure what its worth if running okay but I would suspect 5 grand would catch it. I always hate to try to by something not running. just don't seem to have good luck buying them that way. cost a fortune just to fill the fuel tank and change out oils in that thing. thanks norm
darrel in ND View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2018 at 12:25pm
I sure wouldn't mind having that bad boy, but getting it home would eat my lunch money up in a hurry. Bet ya need ear plugs to run that thing. I ran an old ford half cab over semi around the farm here for many years, and it had a 6-71 Detroit. Quite possibly that's why my hearing isn't worth a now. I sure would like to hear one of them 6-110's run some time. Leland brothers have a couple of them, and say that they really have a "deep throat" sound to em. Darrel
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2018 at 12:33pm
Norm.   these old things are built to last and you can fix them if the parts can be had.  that being said.  ours havnt broken much and keep going.  nice thing about the Detroit is you can still get parts!
here is me and my dad pushing side by side.  Hd16 and HD15 w/6-71
[TUBE]oJkvHVeP2Tg[/TUBE]
jerbob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jerbob Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2018 at 12:49pm
Would be a fun project if you could get it hauled and started. It would appear that the winch alone would be worth half of that cost.
JC-WI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JC-WI Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2018 at 1:36pm
Yea, would be fun to have that one...
 Would buy it in a heart beat but will cost more to move it from there to here than it's worth.Cry
rickv57 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rickv57 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2018 at 2:41pm
I looked at that 15 and passed I believe it has possible flywheel issues and not quite as pretty as the pictures show, undercarriage looked about 35 or 40% remaining not to say that it could not be a good worker
Edited by rickv57 - 08 Jan 2018 at 3:13pm
This page was generated in 0.197 seconds.
