Powermax Hydro Rebuild
IBWD MIke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Topic: Powermax Hydro Rebuild
    Posted: 06 Jan 2018 at 5:35pm
I've got a line on a Simplicity Powermax not sure which model exactly, but it's the same as a 720. It has a bad hydro in it, how much would it cost roughly to get this thing overhauled?
ac720nut View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac720nut Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2018 at 5:38pm
I don't know the exact cost but finding the parts would be the big thing. A gentleman from Canada just recently did one and has it documented on here.
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2018 at 7:02pm
I seem to remember that thread. Thanks for the reply.
orangeman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangeman Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2018 at 10:28am
IBWD Mike:  I think if you do a search using Rustydollar that will bring you a wealth of information on the hydro rebuild that he tackled.
Lots of good information and  much can be learned through the work that he did and was kind enough to post.
Orangeman
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2018 at 11:09am
Ok, next question. I have done business with the potential seller a couple of times already, great guy. I don't want to insult him on an offer but don't want to overpay for this thing either. What's a fair price for a good running (original Onan) Powermax with a bad hydro? Has great tires on the back fronts aren't much.
Brian S(NY) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian S(NY) Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2018 at 1:41pm
is it complete with front and rear pto? does it have the three point hitch?
any attachments?
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2018 at 5:10pm
Before you assume hydro is bad I would at least verify oil level by unscrewing the stick to check. How fresh of a filter and oil? My 720 would barely move when I first ran it as it had been setting for awhile before I purchased it. New oil and filter resolved it. Those things are fairly bullet proof if proper care is given. Has it been professionally diagnosed?
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2018 at 10:06am
I will have to get back with the seller in the spring as he has went South for the winter. I'm pretty sure the oil level and filter are good. He is a good AC man. If it was something simple I think he would have caught it.
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jan 2018 at 9:47am
I had the hydro "go out" on my 720 about 10 years ago. I pulled it out and apart, and all that was wrong was the roll pin that connects the shift lever to the swash plate had sheared off from years of back and forth use. I was able to get all the seals, gaskets and needle bearings, and pins from a Simplicity dealer. The pump group looked really nice and clean still, though the charge pump was a little rough, and it was very expensive, so I just re-used mine. When using it hard, it does get slow to lift when really hot, but it still moves and raises the deck ok. The charge pump provides the hydraulics for the lift.I run Dexron in mine, just like called for in owner's manual.
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jan 2018 at 11:41am
Thanks Ed, I hope I can get this thing bought. After getting my 720 last year and using the front blade I would like to have one tractor for that and one for the mower deck.
Edited by IBWD MIke - 13 Jan 2018 at 12:07pm
rustydollar View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rustydollar Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jan 2018 at 8:40pm
Deleted by author
Edited by rustydollar - 16 Jan 2018 at 3:10am
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jan 2018 at 9:23am
Thanks, if I get this thing bought in the spring it will be interesting to see what's actually wrong with it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote rustydollar Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jan 2018 at 11:09am
Deleted by author
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jan 2018 at 11:02am
Good info, thanks.
bill(soh) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bill(soh) Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jan 2018 at 9:57am
I have 620 mower that just stopped moving, figured hydro went out. To make a long story short finely figured out all splines on stub axel were worn clear off one side.
D-15,CA,I-400,C,180 2-620's,2-110's,112,718,716,
5015, agco 1718
