D15 II not running right |
Post Reply ![]() |
Mikez ![]() Orange Level Access ![]() ![]() Joined: 16 Jan 2013 Location: Usa Points: 8649 |
![]() ![]() ![]() ![]() ![]() Posted: 05 Jan 2018 at 12:57pm |
Hi. Pops was plowing snow, says that it ether full throttle or idling no in between. Think is governor or carburetor. Thanks
Tracy Martin TN ![]() Orange Level Access ![]() Joined: 11 Sep 2009 Location: Gallatin,TN Points: 10714 |
If all has been working OK before. Weather might be the culprit, ice or blockage of some kind around linkage. HTH Tracy
jaybmiller ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Location: Greensville,Ont Points: 24415 |
I had to install 'side shields' on my D-14 last week. It channels the rad/engine heat to keep engine parts ,like carb, warm...
Side shields were made from old 'election' signs, plastic, corrugated, 1 nut and bolt holds them on ! Troy's been fine ever since ! Jay |
MACK ![]() Orange Level ![]() Joined: 17 Nov 2009 Points: 7664 |
Governor may have come apart. MACK
He had it in the garage so is was warm. Guess thinking back it has been acting up for some time
WD45 ![]() Orange Level ![]() ![]() Joined: 20 Sep 2009 Location: STAYNER,ONTARIO Points: 954 |
Check the gas flow at carb. Drain gas tank and put fresh number 1 gas in tank.
Fred Dunlop, G,B,CA, WC,WF, 3 WD45`s,gas, diesel and LP,U,D10 series III, D12,D14,D15 SERIES II,D17 Series IV in Gas and Diesel ,D19 GAS and D21,170 185,210 ,220 an I-600 8070 fwd, 716H and 1920H
dt1050 ![]() Orange Level ![]() Joined: 05 Jul 2011 Location: central pa Points: 1078 |
make sure linkage isn't binding up any were. the person who had my wd45 before me put a nail in the govoner linkage to the carb, it was to long and was hitting the block when the govoner would try to kick in. dt
Ok guys thanks.ill have dad check your those things
LeonR2013 ![]() Orange Level ![]() ![]() Joined: 01 Jan 2013 Location: Fulton, Mo Points: 3500 |
Is it over reving when you open it up with no load? If it does, more than likely You have broken weights in the gov. DO NOT start it if it does. Get all the pieces out first. Also check the gov. shaft for slack in the bushing. They'll break brand new ones with a worn shaft and bushings.
Post Reply ![]() |
