WD air cleaner gasket
Matt Tallant View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matt Tallant Quote  Post ReplyReply Direct Link To This Post Topic: WD air cleaner gasket
    Posted: 04 Jan 2018 at 5:31pm
Anyone have a good source for the oil cup gasket for the WD?TIA,Matt
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jan 2018 at 5:41pm
I had to make one or two. Very thin cork gasket. I can remember seeing one on the WD45 air cleaner??
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jan 2018 at 6:01pm
You can find a rubber O-ring that will work just fine.
Brampton 02 gt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brampton 02 gt Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jan 2018 at 8:50pm
I ordered one from ago and it is a thin felt strip. I am not sure how even to make it work. I don,t use anything and it doesn't really leak or sweat oil.
EPALLIS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote EPALLIS Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jan 2018 at 9:11pm
I'm with Brampton.  Don't use one and have no issues so far.
Phil48ACWC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Phil48ACWC Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jan 2018 at 6:52am
I made 3 gasket rings out of a Wheaties box and stacked them up. they conformed to any regularities and sealed perfectly.
LeonR2013 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LeonR2013 Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jan 2018 at 7:02am
The breakfast of champions.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jan 2018 at 7:17am
The gasket is there for a reason. I'd imagine under load there is dust possibly being drawn in thru that area if it isn't sealed up somehow. I'm telling you, a proper thickness and diameter O-ring works really well.
polarbear View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote polarbear Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jan 2018 at 5:01pm
i have two of them still available from AGCO
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matt Tallant Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jan 2018 at 6:40pm
How is the quality?
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jan 2018 at 9:10am
Oil level in the bowl must be pretty low.  I have mine filled to the mark and with no gasket, it drips out pretty steady when using the tractor.  Looking at getting a gasket in the next couple of weeks.  Hopefully that will help.
Post Options Post Options   Thanks (0) Thanks(0)   Quote polarbear Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jan 2018 at 12:12pm
from AGCO good quality
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matt Tallant Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jan 2018 at 12:49pm
Are they cork like original?
Allis dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jan 2018 at 1:23pm
Sandy Lake won't order them anymore. They say the new AGCO ones are a little too short and don't seal all the way around
Post Options Post Options   Thanks (0) Thanks(0)   Quote polarbear Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2018 at 12:06pm
they are cock well satisfied
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matt Tallant Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2018 at 1:00pm
Thanks Polarbear!!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote polarbear Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2018 at 1:05pm
you are very welcome
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2018 at 2:51pm
Spellcheck polarbear, spellcheck
Wink
I am a Russian Bot
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2018 at 3:15pm
I had no idea there was supposed to be a gasket there. Plus one more on the spell check...
Post Options Post Options   Thanks (0) Thanks(0)   Quote polarbear Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2018 at 12:54pm
opps!!!!!!!!! CORK
Edited by polarbear - 09 Jan 2018 at 12:55pm
This page was generated in 0.506 seconds.
