HD 11B rear axle oil seals
Argo2 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Argo2 Quote  Post ReplyReply Direct Link To This Post Topic: HD 11B rear axle oil seals
    Posted: 02 Jul 2010 at 7:34am
Does any one have or know where I can get all the parts for the oil seal assembly behind the rear drive sprocket on a HD11B?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jul 2010 at 8:20am
Might try Northern Tractor in Osseo MN.
Thill Track and Tractor in Eau Claire WI
Another preson who posts under some other crawler posts is in Canada I believe also , look in some HD5 posts in this section and he is listed there gemdozer@hotmail.com
Edited by Coke-in-MN - 02 Jul 2010 at 9:27am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Argo2 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jul 2010 at 8:28am
Would you have a contact number? Do they have a web site? Not familiar with these places as I live in northern Canada. Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jul 2010 at 9:31am
http://www.thilltractor.com/dismantled.htm
 Their list says they have H3 up in AC machines to part out
Kipn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kipn Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jul 2010 at 10:02am
gemdozer is out of Montreal.
1961 H3
Kcgrain View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kcgrain Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jul 2010 at 11:06am
 I am not sure of the seal you are talking about, but Allis Chalmers was not big on using odd sized stuff, so you could probably take the old seal out and to a bearing shop, tractor dealer, automotive store and they could probably cross it for you.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jul 2010 at 11:43am
Unsure of the seal either but many AC seals were a bellows type seal that is totally different than a shaft seal most are familiar with. They glue into position and a spring loaded expansion type and not the closure type used on shafts.
gemdozer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote gemdozer Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jul 2010 at 3:24pm
I am still have some nice HD11 used bellow seal ass. (5 pieces)
Diesel Smoke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Diesel Smoke Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jul 2010 at 8:34pm
NEED TO PURCHASE PARTS FOR ALLIS CHALMERS DOZERS ?  ANY PART YOU NEED FOR THAT DOZER CAN BE PURCHASED FROM THE FOLLOWING COMPANY.
www.minnpar.com   If you have a parts book  and can give them the  PART NUMBER THAT WILL MAKE IT EASY.  IF YOUR A PRIVATE PARTY WANTING TO PURCHASE YOU WILL HAVE TO GO THROUGH ONE OF THERE DISTRIBUTORS.  YOU CAN ALSO GO TO THERE WEB PAGE AND PUT IN THE PART NUMBER AND THEY WILL TELL YOU IF IT IS IN STOCK. tHEY MAKE PARTS FOR LOTS OF DIFFERENT CONSTRUCTION EQUIPMENT. THIS IS WHERE THE DEALERS GET THERE PARTS. WE OWN A HD-11EP THAT IS IN TOP SHAPE. HOPE THIS WORKS FOR YOU AS IT WORKS GREAT FOR US. GOOD LUCK !
Post Options Post Options   Thanks (0) Thanks(0)   Quote Diesel Smoke Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jul 2010 at 8:38pm
PLEASE READ MY POST UNDER  THE NAME OF  (  DIESEL SMOKE.)  THAT WILL GET YOU YOUR PARTS. NEED MORE HELP JUST CONTACT US..
GOOD LUCK,   DIESEL SMOKE.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Diesel Smoke Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jul 2010 at 9:58am
ALLIS DOZER PARTS  :  HERE IS ANOTHER OLD TIME ALLIS DEALER WITH TONS OF PARTS.
                STEPHENS  EQUIPMENT.    www.StephensEquipment.com
New & used Fiat - Allis  Chalmers  parts.     Ask for Albert Hodill.   Toll free number
        1-800-652-5547    Sarver, Pennsylvania    16055
This page was generated in 0.234 seconds.
