Difference between a 6070 and 6080
victoryallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote victoryallis Quote  Post ReplyReply Direct Link To This Post Topic: Difference between a 6070 and 6080
    Posted: 01 Jan 2018 at 12:47pm
What are the physical differences between a 6070 and a 6080? More than the intercooler and hp?
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2018 at 1:13pm
The 6070 was an upgrade of the 6060. The transmission was upgraded to the 12 speed fully synchronized transmission found in the 6080 and optional 16.9-34 tires. Power increase to 70 hp. Only 972 were produced.
Stan R View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan R Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2018 at 1:51pm
10
4w-220 Butch View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 4w-220  Butch Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2018 at 2:42pm
6080 has heavier wide front end
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2018 at 3:09pm
The CLUTCH is smaller on the 6060/6070. Other than that it is the same chassis and maybe rear tires sizes vary, which was the customers choice on those.
littlemarv View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote littlemarv Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2018 at 5:19pm
StanR took my answer.
The mechanic always wins.
hillmonkey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote hillmonkey Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2018 at 5:52pm
How was the increase in power obtained from the 6060 to 6070 to 6080?
 CI,turbo,injectors,inj-pump or a combo of those?
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2018 at 6:02pm
The addition of a Intercooler added the extra hp from what I read. Same 433T engine.
Tim (Cent.WI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tim (Cent.WI) Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2018 at 6:36pm
From my understanding the 6070 was a 6060 with a 12 speed fully synchronized transmission and they raised the compression to get the extra HP over the 6060. The compression on the 6080 was raised at that time as well but the 6080 was never retested. Alot of people say these later 6080s were pushing 100hp, I have one of the last 6080s but have never had it on a dyno, but it seems to have more than 83hp. The rear end and front end on the 6070 were also a bit lighter than the 6080.
AC7060IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2018 at 10:12pm
I know the 433 engines were AC. Which other components were foreign & which were Allis Chalmers?
Charlie175 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2018 at 6:28am
Transmission back was Fiat Transmission related to their 880 tractor series.
Charlie
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2018 at 6:35am
Forgot to add this was done as A-C did not have a "Live" PTO in this HP range. A-C Stuck with the PD way too long as a Live PTO tool IMHO. I think most users preferred using the foot clutch to stop movement rather than the PD neutral.
Charlie
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tim (Cent.WI) Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2018 at 7:04am
Front axle on the FWA versions was also Fiat
Eldon (WA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2018 at 10:40am
6080 would be the perfect tractor if it had the power director....or a power shift of some kind.
ALLIS EXPRESS!
This year:
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2018 at 11:28am
Yes a PD would be great even if it didn't have the neutral.
Synch shifting is OK, but not the best
Charlie
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2018 at 12:23pm
That, along with about 20% more fuel output from the injection pump. The 6060 pump actually supersedes to the 6070 pump which is basically the same. The injectors and turbo are the same across all 3 models.
Lester View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lester Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2018 at 12:26pm
Allis raised the compression on latter 433 so they would start better and put a milder turbo on the later 433 too .
Post Options Post Options   Thanks (0) Thanks(0)   Quote victoryallis Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2018 at 1:55pm
Sounds like a good way to screw up a perfectly good tractor.
Peterson View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Peterson Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2018 at 8:18pm
Only way to make a 6000 series better would be a shuttle shift. It's one of the best series of tractors allis ever had. That's why we have 4 of them. Could you one or two more.
7095-685I at 255hp, 8070-225HP,8050-210Hp,8030 with 155HP,220 with 670T engine with A-pump, 7580, 185 with 140HP, 2-6080's,6070, S4 D17,wd45,CA,st34 agco, S1 D17 with 3500MK2
Ron(AB) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ron(AB) Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jan 2018 at 12:32am
Back to the OP.
There is approx. 3 inches difference in the wheelbase.
That will make a noticeable difference in a tight spot.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jan 2018 at 8:15pm
Wouldn’t a 6060 with its live pto and a PD have been sweet? Great tractor, dad has one, but man a power director with the synchronized trans would been sweet.
This page was generated in 0.172 seconds.
