Cleaner
jerbob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jerbob Quote  Post ReplyReply Direct Link To This Post Topic: Cleaner
    Posted: 28 Dec 2017 at 6:15pm
Hello AC friends.
Looking for a good/great de greaser or cleaner? I've used Simple Green, Brake Cleaner, Parts Cleaner Solvent and want your suggested "Go To" cleaner or degreaser.
Thank you.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 28 Dec 2017 at 7:47pm
simplest, cheapest (for now), diesel, regular gas, a little alcohol and dawn soap.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 28 Dec 2017 at 8:50pm
Purple power from wal-mart...
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 28 Dec 2017 at 9:21pm
If you have a Sams Club in area they have some commercial cleaners by the gallon - one good one is a heavy duty de-grease and grill cleaner - they also have grease and floor cleaner for lighter work .  A floor stripper and wax remover is also good for light work or wax removal .
 Gunk CS concentrate mixed with diesel also works but the emulsion may be something else to deal with after use when washed with water .
Tad Wicks View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tad Wicks Quote  Post ReplyReply Direct Link To This Post Posted: 28 Dec 2017 at 10:19pm
One thing that I have used to degrease nasty engines and nasty tractors is oven cleaner, I wouldn't advise getting it on good paint. Super clean is the other if you have a pressure washer, it works pretty well.    Tad
LeonR2013 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LeonR2013 Quote  Post ReplyReply Direct Link To This Post Posted: 29 Dec 2017 at 3:42am
If you're degreaseing a concrete flour put kerosene on it and let it soak for a while, then broom it with a stiff broom. After everything is emulsified real well throw kitty litter on and let it set until dry and sweep it up. Cleans a floor better and with less work than anything else that I ever used.There are no stains left.
dustydoo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dustydoo Quote  Post ReplyReply Direct Link To This Post Posted: 29 Dec 2017 at 5:26am
oven cleaner works great if you are planning on repainting and its cheap at the dollar stores !
Post Options Post Options   Thanks (0) Thanks(0)   Quote jerbob Quote  Post ReplyReply Direct Link To This Post Posted: 29 Dec 2017 at 6:22am
Thank you DMiller. Will mix up s small batch and try it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jerbob Quote  Post ReplyReply Direct Link To This Post Posted: 29 Dec 2017 at 6:23am
Thank you Dusty.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jerbob Quote  Post ReplyReply Direct Link To This Post Posted: 29 Dec 2017 at 6:24am
Thank you Leon. Good idea.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jerbob Quote  Post ReplyReply Direct Link To This Post Posted: 29 Dec 2017 at 6:25am
Thank you Tad . Will give it a shot
Post Options Post Options   Thanks (0) Thanks(0)   Quote jerbob Quote  Post ReplyReply Direct Link To This Post Posted: 29 Dec 2017 at 6:26am
I just picked some up and will give it a try
Randaleky View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Randaleky Quote  Post ReplyReply Direct Link To This Post Posted: 29 Dec 2017 at 7:51am
I use Blue Wolf for machinery. I spray it on the entire machine and let it set for 5 min. and pressure wash off.   Wal Mart has it in one gallon size. Not expensive.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jerbob Quote  Post ReplyReply Direct Link To This Post Posted: 29 Dec 2017 at 7:53am
Great news. Making a Walmart run to check it out
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 29 Dec 2017 at 10:22am
Wrong time of the year for them kerosene, diesel or gas floor cleaners as fumes and heat source create a explosive mixture just waiting for the right condition to be set off .
walnut1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote walnut1 Quote  Post ReplyReply Direct Link To This Post Posted: 29 Dec 2017 at 10:32am
Oil Eater: Tractor Supply, Costco, NAPA
Post Options Post Options   Thanks (0) Thanks(0)   Quote jerbob Quote  Post ReplyReply Direct Link To This Post Posted: 29 Dec 2017 at 4:02pm
Yea I hear that for sure. Thanks for the insight.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jerbob Quote  Post ReplyReply Direct Link To This Post Posted: 29 Dec 2017 at 4:03pm
Will look that one up. Thank you. Have not heard that one before. Have a Great New Years day.
HD6GTOM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6GTOM Quote  Post ReplyReply Direct Link To This Post Posted: 29 Dec 2017 at 7:52pm
Car dealers use a product called Red Power. Cleanup man swears by it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jerbob Quote  Post ReplyReply Direct Link To This Post Posted: 29 Dec 2017 at 8:16pm
Thank you for that. I will look it up
