Rc ring and pinion in a wf
Matt -mid-mich View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matt -mid-mich Quote  Post ReplyReply Direct Link To This Post Topic: Rc ring and pinion in a wf
    Posted: 21 Dec 2017 at 8:51pm
Pros and cons to putting rc ring and pinion in a wf I understand I need to machine another bearing on the pinion and best to use the wf carrier any input would be great tractor is just to fast for the 3mph speed limit rules running 10%over Rpms with d17 m code engine at 65 hp at pto
We have 86400 seconds to everyday make every second count because we never know when it's our last
CAL(KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 22 Dec 2017 at 9:32am
pinion has place for bearing, just not installed on rc.   what size tires are you running?  what rules are used?  natpa?
Edited by CAL(KS) - 22 Dec 2017 at 9:33am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matt -mid-mich Quote  Post ReplyReply Direct Link To This Post Posted: 22 Dec 2017 at 3:09pm
Running a set of 14.9 28s top cut with a 18in draw bar weights can extend 11 ft forward from center of rear axle also run sometimes 16.9 24s top cut seem to do better with the 14.9s natpa rules
Ken(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ken(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 23 Dec 2017 at 6:07am
The rc pinion shafts were not ground to accept the bearing, just rough forged in that area, any decent machine shop should be able to finish grind it though.
