220 front turf tires?
Tim (Cent.WI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tim (Cent.WI) Quote  Post ReplyReply Direct Link To This Post Topic: 220 front turf tires?
    Posted: 21 Dec 2017 at 3:13pm
Does anyone know if 220's came with front turf tires from the factory? If so what size were they? I would like to put a pair on my 220.
I like the looks of turf tires on the big horses like 210's, 220's and 7060 and 7080's
Brian F(IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian F(IL) Quote  Post ReplyReply Direct Link To This Post Posted: 21 Dec 2017 at 3:49pm
I believe the only tractor that came from the factory with the diamond stud (or turf tire) was the 7080.  At least from my recollection of what came into Dad's dealership in the '70's that was the case.  Two Ten's, Two Twenty's, 7030, and 7050 all came out with a tri-rib tire from the factory.  Again, just my experience but there may have been other dealers with something different.
JimWenigOH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JimWenigOH Quote  Post ReplyReply Direct Link To This Post Posted: 21 Dec 2017 at 4:07pm
I was thinking about putting those on my 220 but was advised against it by the tire dealer. He said corn stalks are hard on them. I went with 4 rib instead.
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 21 Dec 2017 at 8:07pm
those diamond tread ones look  kind of cool to me
LB0442 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LB0442 Quote  Post ReplyReply Direct Link To This Post Posted: 21 Dec 2017 at 10:29pm
Ya I like the looks of them.  Got a set from the salvage yard for the 7080.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tim (Cent.WI) Quote  Post ReplyReply Direct Link To This Post Posted: 22 Dec 2017 at 8:00am
Just love that look! What size are those?
Post Options Post Options   Thanks (0) Thanks(0)   Quote LB0442 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Dec 2017 at 9:20am
They are 18.4 x 16.1.
Calvin Schmidt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 22 Dec 2017 at 9:45am
18.4 x 16.1  I think they make a 220 look mean
HD6GTOM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6GTOM Quote  Post ReplyReply Direct Link To This Post Posted: 22 Dec 2017 at 10:32am
In the years I was in the farm tire business I saw several 220's with the diamond tread. I do not know if they were stock. I do remember several new 7080's at R&R equipment in Indianola came with the diamond treads.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tim (Cent.WI) Quote  Post ReplyReply Direct Link To This Post Posted: 22 Dec 2017 at 11:50am
Calvin that is what I am talking about, that does look Mean!!
What do you have for front rims on it?
aras View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote aras Quote  Post ReplyReply Direct Link To This Post Posted: 22 Dec 2017 at 1:58pm
They are 16" wide -- the old designation for 16.1 was 16A for rim diameter.  They have a huge offset and reinforcing rings from the factory.  We have a couple sets on our tractors....
daveingreenbay View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote daveingreenbay Quote  Post ReplyReply Direct Link To This Post Posted: 22 Dec 2017 at 4:06pm
I know where I can put my hands on a pair of Goodyear 18.4x16.1 Diamond tread tires, in case anyone is interested.  54155 zip code.
AC7060IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 23 Dec 2017 at 6:49am
Have you priced a new 18.4-16.1 diamond tread (knobby) tire only lately? Make sure you're sitting down.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 23 Dec 2017 at 6:56am
As far as I know, the first farm tractor to offer those front tires was the 7080 in very late 1974.
victoryallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote victoryallis Quote  Post ReplyReply Direct Link To This Post Posted: 23 Dec 2017 at 7:00am
They look cool but wouldn’t they steer worse.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 23 Dec 2017 at 7:04am
Stumbling through a local salvage yard looking for a matching 20.8 x 38 radial for the duals, I saw these tires on Kubota rims and another wore out pair of diamonds on MF 2745 rims. The rims are the same as a 7080 and fit perfectly.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 23 Dec 2017 at 7:09am
Calvin, your AC 220 looks awesome! Does it's rear duals have Mexican hat centers?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 23 Dec 2017 at 7:18am
Steering isn't really an issue on a tractor with power brakes. The improved ride is awesome when you run the air between 15 and 20 psi.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 23 Dec 2017 at 7:21am
Yes it has Mexican Hat duals. It also has a 3500 MK II engine that was factory speced as a "On Highway" and has a factory inline injection pump. Was a standby water pump power unit with 82 hrs when I got it. Just didn't look right without and intercooler. I call it my 220 XT.
Edited by Calvin Schmidt - 23 Dec 2017 at 7:24am
darrel in ND View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 23 Dec 2017 at 7:24am
I love them diamonds also. When I was a kid, a neighbor had a two twenty with em on the front. Looked identical the one Calvin has posted, duals and all. Thought that had a unique factor that was just awesome. If I had the ways and means to do it, every tractor I own would have them. Love the looks of your front tires, too, LBO442. Darrel
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tim (Cent.WI) Quote  Post ReplyReply Direct Link To This Post Posted: 25 Dec 2017 at 12:14pm
Are the only rims that work on the turf tires the factory ones that came on 7080s?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 25 Dec 2017 at 2:36pm
The rims on my 220 above are from a MF 2745.  Rims were vendor supplied
Adam Stratton View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Adam Stratton Quote  Post ReplyReply Direct Link To This Post Posted: 27 Dec 2017 at 5:19pm
I've got 2 pair, both are mismatched and both were on combine rear axles, one set of 6 bolt 1 set of 8 bolts that have split rims. I would take $250 for a pair if you're interested I can send pics, located in SWMO.
Dkienzle View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dkienzle Quote  Post ReplyReply Direct Link To This Post Posted: 27 Dec 2017 at 9:32pm
I agree with victoryallis, the look great and ride awesome, but the steering is terrible especially in worked ground they just slide. We took ours off our 7080 and put a 4 rib on it.
This page was generated in 0.227 seconds.
