WD45Diesel banner day
Michael Crowe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Michael Crowe Quote  Post ReplyReply Direct Link To This Post Topic: WD45Diesel banner day
    Posted: 17 Dec 2017 at 2:01pm
Thursday I went to help a friend get his 45 diesel running. The pump was 180 degrees out of time on the Crankshaft, the pump drive gear was one tooth off, and the pump head was a full two revolutions of the pump drive shaft off. In addition the fuel shutoff cylinder was frozen and it couldn’t be shutoff without putting your hand over the air intake. The Governor spring was so tight that as soon as the throttle lever broke over center it went to full throttle. Also the return line and fuel inlet lines were reversed. And despite all that it would start with a whiff of ether and run poorly. We corrected all the above problems, and started to bleed everything. A friend was teasing us that we would need a can of ether to get it going and I told him no we wouldn’t. Once the two filters were bled and it turned over a few times it started on its own and one by one I tightened the line nuts to the injectors and it smoothed out and ran real nice and would idle down to a slow purr with that 230 buda sound. I was relieved that it all worked out and we both were just amazed at how well it ran. He’s had the Tractor for several years and it never ran right until now.
A big thanks to Tom Foss’ old AC webpage for a refresher on all the timing marks. I’ve studied that page many times and did so again the night before just so I could work from memory and not waste time going back to a manual or webpage.
Also thanks to Don Bradley for talking me through the whole procedure on our way back from the Missouri AC club winter meeting. He told me to not trust the timing marks but to pull the valve cover and make sure your at tdc on #1 cylinder. Turns out the guy who put it all back together painted the wrong marks and when we initially turned the crank to the fpi mark, the pump drive gear had been painted but was still one tooth off but #6 cylinder was on tdc, not #1.
All in all a fun day and we got it running well.
The 15th Annual Exclusive AC Swap Meet will be held in Boonville, MO, March 6-7, 2026. See the club website for details: http://www.moacclub.com/
LeonR2013 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LeonR2013 Quote  Post ReplyReply Direct Link To This Post Posted: 17 Dec 2017 at 4:26pm
Those are the kind of days you enjoy isn't it? I'd say there aren't a half dozen 24 year old mechanics in the state of Mo that could have done that. Congrats.  Leon
Don(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 17 Dec 2017 at 6:53pm
I just knew you get her going, We have tacked about the old Buda engines so much you are as up on them as most  mechanics out there. GOOD JOB!! and now you can come help me time all the old WD45's I have here that need rebuilt.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Michael Crowe Quote  Post ReplyReply Direct Link To This Post Posted: 17 Dec 2017 at 8:30pm
Leon I haven’t seen 24 in a real long time, but thanks just the same!
Auntwayne View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Auntwayne Quote  Post ReplyReply Direct Link To This Post Posted: 17 Dec 2017 at 8:50pm
    Good job Michael.
Dad always said," If you have one boy, you have a man. If you have two boys, you have two boys". "ALLIS EXPRESS"
Reindeer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Reindeer Quote  Post ReplyReply Direct Link To This Post Posted: 17 Dec 2017 at 10:16pm
It is just so satisfying when it all comes together!  Makes us stand a little taller, and walk a little faster!
Edited by Reindeer - 17 Dec 2017 at 10:17pm
This page was generated in 0.199 seconds.
