CA Hydraulics not holding up
TNOBLES View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TNOBLES Quote  Post ReplyReply Direct Link To This Post Topic: CA Hydraulics not holding up
    Posted: 16 Dec 2017 at 7:01pm
Plowing snow today with CA. All of sudden plow will not "hold". Will lift, but not stay up. Suggestions? Thanks.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 16 Dec 2017 at 9:05pm
I would look at the linkage to make sure something did not come loose or slip. The spool centers itself to "hold" either external linkage is sticking / off center, or bigger problem inside..........  You might post your note in the "tractor" forum instead of the "talk" forum.
