Diesels and cold starts |
Ian Beale
Joined: 03 Oct 2011 Location: New South Wales Points: 1009 |
Topic: Diesels and cold startsPosted: 17 Dec 2017 at 2:49am |
In this thread
http://www.yesterdaystractors.com/cgi-bin/viewit.cgi?bd=ttalk&th=1885492 There is this comment by JayinNY "I don't want a diesel because it won't start in the winter. Not what I think, but heard others say this." Which caused me to check the parts book for our Fiat Allis 10 to see if I had missed any cold start aids. Apparently there weren't any - apart from a cold start button on the pump. We don't have any problem but we also don't get below about -10C at times. What did they have in N America? |
pinball
Joined: 28 May 2014 Location: missouriu Points: 6458 |
Posted: 17 Dec 2017 at 6:51am |
A block heater will help. some people and some machines has a button for a shot of either. If a diesel motor is running correctly and your battery will turn it over fast enough then It will start in cold weather. a lot of gas motors has trouble starting. Battery maintainer will help keep the battery up.
DiyDave
Joined: 11 Sep 2009 Location: Gambrills, MD Points: 55264 |
Posted: 17 Dec 2017 at 8:52am |
Some engines are just harder to start, in the cold, both gas and diesel. I have a DD grader, that will start in the coldest weather no probs, while the D19 (roughly the same motor) required at least an hour of pre heating. Rather than installing coolant heaters in alla my diesels, I have a coleman tent heater, that I slide under the oil pans of the balky ones, to preheat the entire motor, for about an hour, if U absolutely have to start them, in the few days of cold weather we have here, in MD...
DMiller
Joined: 14 Sep 2009 Location: Hermann, Mo Points: 35650 |
Posted: 17 Dec 2017 at 8:55am |
My 7G is a pig below 30, the 180 below 20.
jerbob
Posted: 17 Dec 2017 at 9:03am |
Agree with comment about different engines start different. My Bobcat fires up at any temp. 30 seconds of glowplug will fire up at 0 or colder. My 1855 Oliver is a baby pig. Needs 2 minutes of glow plug or overnight with block heater plugged in, my HD 16 so far takes right off and it's been 12 degrees already. I think the new batteries and 00awg new cables help.
All are diesel. |
Coke-in-MN
Joined: 12 Sep 2009 Location: Afton MN Points: 42263 |
Posted: 17 Dec 2017 at 10:18am |
I have a cold start kit on my FD5 Fiat Dozer with the 4 cylinder Fiat engine - consists of a canister like a propane torch with either and then line to intake .
NEVER had to use it - ran machine at -15 F removing snow from couple jobs where drifted roads and drives were a problem I was amazed that the Fiat engine started so easily when cold - in fact not much difference from when warm out - just a few more revolutions of the crank and little more smoke for a minute or so
TramwayGuy
Joined: 19 Jan 2010 Location: Northern NY Points: 11856 |
Posted: 17 Dec 2017 at 2:16pm |
If you use a synthetic diesel oil, you are way ahead of the game. 5W-40 or 5W-30.
Dozer
Joined: 16 Aug 2011 Location: SW New York Points: 689 |
Posted: 19 Dec 2017 at 5:03pm |
A friend flew small aircraft in Alaska. Periodically he would have to land the airplane because he was trapped by the weather. He would wait out the storm. He would drain the oil and heat it over a fire and put it back in the motor before trying to start it. Even gasoline motors have difficulty when it is cold.
Last week we had a few days with snow and below zero temperatures. My Kubota diesel started but did not run well because I was still using summer grade diesel. I went to purchase anti jell fuel supplement but they were all sold out. It is warmer now and my Kubota runs great. I will have to get some anti jell when they restock. |
DiyDave
Posted: 19 Dec 2017 at 6:12pm |
Yep, the anti-gell is important. I lucked out a coupla years ago, when they changed out to uls fuel, all the old anti-gell ended up either in a dumpster, or at auction, I bought like 20 qts of it fer $5...
DennisA (IL)
Joined: 11 Sep 2009 Location: Ridott IL. Points: 2077 |
Posted: 19 Dec 2017 at 6:39pm |
I have not had issues starting any of the 3 diesels I have as long as the batteries are good.
Thanks & God Bless
Dennis |
Ian Beale
Posted: 19 Dec 2017 at 6:51pm |
We had a 1952 TD6. The original operators manual had instructions down to -50F. IIRC at that level the coolant was mostly antifreeze and the oil was mostly kerosene. I don't recall what the diesel was. Recommended was not to stop it. If you had to then drain the coolant and then the oil and take both inside to keep warm.
Another comment about Edmonton I've heard was "You know it is cold when your VW Beetle in the garage won't start because the oil is frozen" |
Sugarmaker
Joined: 12 Jul 2013 Location: Albion PA Points: 8661 |
Posted: 20 Dec 2017 at 9:54am |
Ian is correct on the old red machines.
I have not tested my 1952 IH TD6 in extreme cold. But the design is unique in that it will start on gas and then when warmed up, switch over to diesel. A good design in the old days. Unit still works good, but is a summer worker (toy) only. :) Regards, Chris |
