D10 Front Wheel Weights |
Post Reply ![]() |
RAR45110 ![]() Bronze Level ![]() Joined: 15 Nov 2016 Location: Cumming, GA Points: 105 |
![]() ![]() ![]() ![]() ![]() Posted: 16 Dec 2017 at 10:58am |
I have a D10 that I want to lift trees with. I have a 3 point boom pole and want to add weight to the front of the tractor. I have not seen the front frame weight for sale or even discussed for this tractor. I have seen front wheel weights advertised. However, even though they look like the ones in the D10 parts manual, they typically say they are for the WD, WD45, D14, D15, D17, but the D10 is not listed. Does anyone know if these weights will also fit the D10? Thanks in advance for your help.
Bob
Larry in NC ![]() Orange Level ![]() Joined: 09 Feb 2016 Location: NC Points: 1050 |
D10 front rims are 15 inch. Weights from B's, C's and CA's would fit. B, C, CA engine side weights would work. You could add fluid to the front tires. If you can fabricate a bracket to attach to the front axle, weights added to the front would probably be most effective.
DiyDave ![]() Orange Level Access ![]() ![]() Joined: 11 Sep 2009 Location: Gambrills, MD Points: 53990 |
Buy a kuboter front weight bracket, They're cheap, and the weights plentiful. Easiset to mount to a series 3 weight, you didn't say what yours is...
Post Reply ![]() |
