WD 45 Brakes
Steve Bright View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve Bright Quote  Post ReplyReply Direct Link To This Post Topic: WD 45 Brakes
    Posted: 14 Dec 2017 at 2:02pm
Going to replace the brakes on a WD 45, Any easy way to accomplish this? Or is it difficult to do?
HoughMade View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HoughMade Quote  Post ReplyReply Direct Link To This Post Posted: 14 Dec 2017 at 2:06pm
Easy?  Not that I know of, but this may help:
[TUBE]nKIJNiCH6p8[/TUBE]
1951 B
Bill_MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill_MN Quote  Post ReplyReply Direct Link To This Post Posted: 14 Dec 2017 at 2:10pm
Luck will dictate how hard a job it is. All depends on how badly the bottom pins are stuck, some can be pulled out with your fingers, others have to be cut with a torch.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve Bright Quote  Post ReplyReply Direct Link To This Post Posted: 14 Dec 2017 at 2:17pm
The reason I will start Tomorrow is because my pins are really stuck
Stan IL&TN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan IL&TN Quote  Post ReplyReply Direct Link To This Post Posted: 14 Dec 2017 at 2:22pm
I hope you have been soaking them for a couple of weeks.  Maybe if you have lived a good and wholesome life then they will come right out.
Also you can ignore the video unless you need to replace the drums and that is rare.
Edited by Stan IL&TN - 14 Dec 2017 at 2:24pm
1957 WD45 dad's first AC
1968 one-seventy
1956 F40 Ferguson
CrestonM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 14 Dec 2017 at 2:25pm
Is there any advice when putting them back together that will keep them from sticking again? Maybe some sort of improved designed pin?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill_MN Quote  Post ReplyReply Direct Link To This Post Posted: 14 Dec 2017 at 2:29pm
Wire brush the holes good, stainless pins and anti-seize
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 14 Dec 2017 at 3:15pm
If they are stuck then you'll end up cutting them out a little at a time. Careful not to nip the brake lining brackets. Cut a slice out, pound the pin in, cut some more and repeat until the outside piece is out and gone. The heat from cutting, in my experience, will loosed the inside piece so a visegrips will twist it out of the housing.  I made my own puller and it pulled the end of the pins off so that doesn't always work. Some people have said they drill and tap the end of the pin and used a slide hammer to pull it out. Allis had, at one time, chromed pins available as replacements which is what I put in my WD. Good luck.
Edited by Lonn - 14 Dec 2017 at 3:16pm
Wink
I am a Russian Bot
B26240 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote B26240 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Dec 2017 at 4:12pm
Lonn is correct in what he said, new pins can be made useing 3/4 cold rolled and if you have access to a lathe the ends can be turned to look like the originals.    I have done several and would advise if you cut the pins to do it outside as there will be lots of smoke from mouse nests even after you blow as much of them out with air before you begine. In my opinion this can be the hardest job you will ever do on one of these tractors but will be most satisfying also.   I did one for a guy and charged him $400 plus parts, he was very happy to pay it as he had been useing the tractor for 20 years with no brakes.
REEDE View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote REEDE Quote  Post ReplyReply Direct Link To This Post Posted: 14 Dec 2017 at 7:24pm
My son and i did the brakes on our WD  late this summer . One pin came out nice , the other had to be cut out with a torch . Insult to injury the brake shoes had worn into the stuck pin. When we finally got the pin out we had hole in a brake drum and a badly nicked up brake shoe. Long story short we learned a new language and some much needed experience .  Good luck.
allisbred View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote allisbred Quote  Post ReplyReply Direct Link To This Post Posted: 14 Dec 2017 at 8:22pm
I had pretty good luck by making a plate (thickness of the groove)with a milled slot to fit the groove in the pin 1/2 the Dia. Then using a pickling fork(tie rod tool), beat in from the tail end of the tractor against the axle housing. Make sure you soak the pin good through the brake assy after removing the covers for days before you start. Be patient and have confidence! Best of luck-- Kevin
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 15 Dec 2017 at 11:38am
Take a bunch of progress pictures! We love to see how these things go, as some of us have not had a chance to do this yet! :)
Don(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 15 Dec 2017 at 12:15pm
Well Chris if you are looking for some live practice on them old hard to get out pins just come on over I always have one or two WD45's here needing them done and I will let you work on one. lolWinkWinkWink
Edited by Don(MO) - 15 Dec 2017 at 12:16pm
This page was generated in 0.157 seconds.
