D17 III gas fan belt size?
paulinkansas View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote paulinkansas Quote  Post ReplyReply Direct Link To This Post Topic: D17 III gas fan belt size?
    Posted: 30 Jun 2010 at 10:12am
I replaced the belts on the D17 that I rebuilt.  The replacement fan/water pump belt was a really really tight fit to put back on.  By tight fit, I mean that there was alot of tension on the belt when it was installed, and that I really had to stretch it to make it go around the lip of the last pulley.  After about 3 hours of use, the new belt broke.  I have a feeling that the belt I put on was the wrong size.
What size belt should I use for the fan/water pump?  How can I tell if it's too loose or too tight?
Thanks.
