few questions on my 190 xt
jb from md View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jb from md Quote  Post ReplyReply Direct Link To This Post Topic: few questions on my 190 xt
    Posted: 29 Jun 2010 at 10:00pm
my 190 is a 67 model i believe its an xt and it has a year round cab on it. i would like to know how to tell if it is an xt, how about land handler what are the differences i have noticed some have some different side panels, also should it have a bar grill or not? you all have been very helpful on some wc questions before, thanks in advance for any help ...Jb
Dans 7080 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dans 7080 Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jun 2010 at 10:50pm
The XT has a turbo.
Hurst View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hurst Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jun 2010 at 11:16pm
XT could be a 301 gas or propane also, but if it's a diesel, it will have a turbo.  Check the ID tag on the engine to tell what engine you have.  If it's a diesel, a 2900 will be a 190xt and a 2800 will be a 190.  If it's a gas or LP, a 2800 will be a 190xt and a 2500 will be a 190.  That doesn't mean the engine couldn't have been swapped and the rear end is from a straight 190, but for a 67 model, I want to say it was before they had done any updates on the rear end for the 190xt, so it just had the same rear end as the 190.  I'm not sure if the 190xt had a distinctive serial number from the 190.  The serial number would be on the bell housing.
Hurst
1979 Allis Chalmers 7000
5800 Hours
allisorange View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote allisorange Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jun 2010 at 6:22am
         A 1967 190XT would have the bar grill.
                           John Carlson
Oldoug View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Oldoug Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jun 2010 at 10:10pm
If it's an XT it will say XT on the serial number.  Any serial number below 19,000 should have sloped fenders and a bar grill.
gcalent View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote gcalent Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jul 2010 at 1:39pm
The serial number should statr with the XT, it should read XT190xxxxx, if it is an XT and not a straight 190
Pullin With AC
Dutchboy Johan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dutchboy Johan Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jul 2010 at 6:04am
Indeed, you can see it on the serial number if it it an XT or not. You'll find it on the lef side of the tractor.
Mine says: 26829XTD
Edited by Dutchboy Johan - 02 Jul 2010 at 6:05am
---> Better by Design <---
Johan Straver, Almkerk/ Netherlands
Allis-Chalmers 190XT Ser.III #26829XTD
