allis 706 b fork lift gas perkins fuel pump ?
steve fischer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve fischer Quote  Post ReplyReply Direct Link To This Post Topic: allis 706 b fork lift gas perkins fuel pump ?
    Posted: 05 Dec 2017 at 8:14pm
I have a fork lift that the fuel pump does not keep up with the carb,when it starts to run out of gas I can use the hand primer and fill the carb and runs fine, new fuel pump same as old one, what runs pump inside the gas engine ,  mounted higher them the diesel it can not be on cam , does it use a rod ? can not  feel it hitting anything when I hand pump it and running
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 06 Dec 2017 at 4:50am
Easiest fix would prolly be an electrical pump, with adjustable output...
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 06 Dec 2017 at 7:42am
foggy memory on the pump - had the same thing with engine pump on my TLB but installing a new pump solved the problem - can't remember how the pump was driven .
Thought it was just long arm that rode on cam lobe.
