Sealed beam headlight bulb part niumber |
Post Reply |
Lon(MN)
Orange Level Joined: 11 Sep 2009 Location: Elk River,MN Points: 1965 |
Posted: 05 Dec 2017 at 5:47pm |
Any one know the bulb number for a sealed beam headlight 12 volt for a D14?
DSeries4
Orange Level Joined: 12 Sep 2009 Location: Ontario, Canada Points: 7330 |
NAPA should be able to look it up for you. Last ones I got came from AGCO though.
markat
Bronze Level Joined: 18 Feb 2015 Location: Missouri Points: 29 |
I was going to post the same question this morning. I checked Napa with no luck. Does anyone know what the part number for the 12 volt sealed beam ,4 and 3/4 bulb is? Napa or agco number, they can cross it to find it. Thanks.
Lon(MN)
The part number I see in the book is 230232
Acdiesel
Orange Level Joined: 15 Jun 2012 Location: Rochester Ohio Points: 2546 |
NAPA 4411
D19 diesel,D17 diesel SER.3 D14 NF,D14 WF, D15 SER.II wf
D15 SER.2 DIESEL,D15 ser.II nf D12 SER.I, D10 Ser.II 2-720'S Gmc,caterpillar I'm a pharmacist (farm assist) with a PHD (post hole digger) |
jaybmiller
Orange Level Access Joined: 12 Sep 2009 Location: Greensville,Ont Points: 22399 |
https://www.walmart.com/ip/GE-4411-35W-12V-PAR36-Sealed-Beam-Aviation-Bulb/37682481?action=product_interest&action_type=title&beacon_version=1.0.2&bucket_id=irsbucketdefault&client_guid=fde71b32-42ae-4c5b-3ffc-10f5f5a4377d&config_id=106&customer_id_enc&findingMethod=p13n&guid=fde71b32-42ae-4c5b-3ffc-10f5f5a4377d&item_id=37682481&parent_anchor_item_id=37682145&parent_item_id=37682145&placement_id=irs-106-t1&reporter=recommendations&source=new_site&strategy=PWVAV&visitor_id=RxYzFJiwEutqBSxqYRGblI
yeah I found it interesting that WallyWorld has them !! I just googled '4411 sealed headlight'... OK have to ask..this is a 4.5" bulb but OP wanted 4.75"..big difference. I know the 4411 is a GE part number, industry reference. Edited by jaybmiller - 07 Dec 2017 at 10:58am |
Ed (Ont)
Orange Level Joined: 08 Nov 2009 Location: New Lowell, Ont Points: 1273 |
Allis Chalmers D14 Light Bulb, Sealed Beam, 12 Volt - 373662R91www.yesterdaystractors.com/Allis-Chalmers-D14_Light-Bulb-Sealed-Beam- 12-Volt_373662R91.html Allis Chalmers D14 Light Bulb, Sealed Beam, 12 Volt for sale, 373662R91. This 12-VoltSealed Beam has Double Contact. It is 35 Watt. Has a 4.365 inch outside diameter. Replaces: L4411, 230232, 70232232, 70276858. for sale. Steiner also lists them. According to them it fits everything from D14 to 175 and 190. Anyone tried them??? Would that be the same as the outer 2 bulbs in a 4 lamp automotive application in older cars? They are double contact. In other words 2 small round low beams.
Edited by Ed (Ont) - 07 Dec 2017 at 3:59pm |
jaybmiller
OK... according to some places it's a 4.5" bulb, commonly used in 'exit' emerg light units...some have them for $6 a bulb....LED ones are kinda pricey..
for some reason I had been looking for 4 3/4" units... 4.5 IS whats on one of my D-14s though who knows if it's correct..... |
DSeries4
Newer D14s with 12 volt systems use 4.5" sealed beam headlights - these are still available. Older 6 volt D14s use 4 3/4" lights that do not look like anything else - these are no longer available.
I did manage to get a smaller sealed beam to fit in the older 6 volt light housing. I got creative with them and they fit nicely. No one would know. |
jaybmiller
hmm that explains my fleet...3 were 6v,but modified for 12,so 'someone' replaced light housings with 4.5 ones (12V).
JoeM(GA)
Orange Level Joined: 12 Sep 2009 Location: Cumming,GA Points: 4630 |
L4411's will work for the 4 3/4, but you will have to split some fuel line to make a rubber ring to take up the space to the clamp
Allis Express North Georgia
41 WC,48 UC Cane,7-G's, Ford 345C TLB |
JC-WI
Orange Level Access Joined: 11 Sep 2009 Location: wisconsin Points: 33805 |
Try some of these for filament lights...
Wagner H7610 50 watt . There are HID's out there too as well as the LED lights which won't look origional unless you spend some big bucks... When converting the old WD45 to 12 volt, I put the Halogen in the old light fixtures with small daps of silicon sealer in four places to keep the glass from rubbing the origional glass lens and then made an assembly in the back side to put tension on the sealed beam... man did that give it light. Refigured the old push pull switch up so I could turn on the front and tailights on the first notch out, and second notch, (all the way out) was for the second set of firecrackers on the hood. Switch all the way in , everything was off. Sure was fun cultivating at night with it... see up close, see out far and see where you been. LOL |
The truth is the truth, sugar coated or not. Trawler II says, "Remember that." |
Post Reply | |
