Hd6
Ebys custom cutting View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ebys custom cutting Quote  Post ReplyReply Direct Link To This Post Topic: Hd6
    Posted: 04 Dec 2017 at 1:36pm
I'm looking at buying a hd6 anything that I should look out for
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 04 Dec 2017 at 1:53pm
Rails, seals on finals, bad rollers. None of which are available anymore.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ebys custom cutting Quote  Post ReplyReply Direct Link To This Post Posted: 04 Dec 2017 at 5:48pm
What size cat is hd6 equivalent to
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 04 Dec 2017 at 11:05pm
It's about a 1 1/2 yd loader , the rear housing is same as HD5 as is the track and sprockets - just more links and rollers .
 Size wise 931 would be similar at 62 HP
Production:
Manufacturer:Allis Chalmers
Factory:Springfield, Illinois, USA
Variants:
HD6A:44-inch gauge
HD6B:60-inch gauge
HD6E:5-roller
HD6G:loader
HD6EP:power shift
HD6AG:turbocharged
Allis Chalmers HD6 Engine:
   Allis-Chalmers 5.6L 4-cyl diesel
full engine details ...
Capacity:
Fuel:37 gal [140.0 L]
Dimensions & Tires:
Weight:13,400 lbs [6078 kg]
Front tire:tracks
Rear tire:tracks
full dimensions and tires ...
HD6 Serial Numbers:
Location:Serial number stamped on the rear of steering clutch housing (upper-right) or on the instrument panel.
- Serial numbers unknown -
Allis Chalmers HD6 Power:
Drawbar (claimed):39 hp [29.1 kW]
Belt (claimed):54 hp [40.3 kW]
Drawbar (tested):49.95 hp [37.2 kW]
Belt (tested):60.51 hp [45.1 kW]
power test details ...
Mechanical:
Chassis:crawler
Cab:Open operator station.
Battery:
Number:2
Volts:12
Page information:
Last update:June 14, 2016
Copyright:Copyright 2016 TractorData LLC
Contact:Peter@TractorData.com
Dozer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dozer Quote  Post ReplyReply Direct Link To This Post Posted: 05 Dec 2017 at 3:38pm
While looking at an HD6 I checked the final drive oil finding it empty. The owner did not know to check the oil and didn't. I think the final drives and steering clutches are the most difficult repairs so that is what I check first. Try to get a 1964 or newer.
Ray54 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ray54 Quote  Post ReplyReply Direct Link To This Post Posted: 05 Dec 2017 at 7:08pm
A D4 D would be a comparable Cat dozer.
This page was generated in 0.115 seconds.
