Oil Pressure
Allis Wd45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis Wd45 Quote  Post ReplyReply Direct Link To This Post Topic: Oil Pressure
    Posted: 30 Nov 2017 at 6:40pm
I have a question about my wd45’s oil pressure when I start it up the needle on the gauge reads about N in the word Normal when warmed up it is at the mark right before the N how much pressure is this and is this something to worry about? Thanks
littlemarv View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote littlemarv Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2017 at 6:55pm
If I remember right, they are 30 psi gauges.
Here's how I tested out my gauge at 10, 15, 20, and 30 psi.
The mechanic always wins.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis Wd45 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2017 at 7:12pm
I do believe I have read that before that they are 30 psi guages thanks for the pictures. I think I'd be okay then at 10 psi
Post Options Post Options   Thanks (0) Thanks(0)   Quote littlemarv Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2017 at 7:18pm
Well, if it's on the mark before the N when it's warm, that might be around 5 psi. Which still might be OK, but I think she is worn.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis Wd45 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2017 at 7:31pm
That’s what I was thinking is there anyway to increase this without a rebuild?
Stan R View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan R Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2017 at 7:34pm
Heavier oil, but why?
CrestonM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2017 at 7:53pm
Personally I don't think heavier oil does much good. It just increases friction to build pressure. Increased friction makes things hotter, and increases wear. I was told it's better to have lower pressure with spec oil than higher pressure with thick oil.
Before I overhauled my B and Ford 8N, each tractor barely registered any oil pressure when hot. When I took them apart, all the bearings in both tractors looked nearly perfect, despite some wear after 70 years.
Now, I've also heard that 5 lbs in a B/C/CA is perfectly fine, but I think on the W series, if the cam bearings are worn bad, that causes a lot of loss in pressure. But, maybe someone else can verify.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2017 at 8:10pm
Got to remember the general rule of thumb for low speed engines is 1 psi, for each 1000RPM...  seen many a b, c, ca run for years at 5psi...
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis Wd45 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2017 at 8:12pm
Ok I’ve got 30w oil and Lucas stabilizer in it
wayneIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wayneIA Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2017 at 8:14pm
On the WD 45 style engines, if the oil pressure is low usually changing cam bearings will bring it back up.  The oil goes to the cam first and if the bearings are loose, you lose most of your pressure there.  A friend had a similar issue, engine was pretty tight  (very little blow by and made good power), but had very little oil pressure.  We changed the cam bearings and brought the pressure back up.
DougS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2017 at 8:47pm
Put thicker oil in and increase the pressure maybe a couple of PSI. So you have slightly more pressure pushing at thicker oil. I don’t see that giving any better oil flow.
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2017 at 9:12pm
Be sure the oil filter isn't a fluted paper junk filter. It needs to be filled with cotton fiber. The pressure drop of the filter sets the oil pressure in the bypass filter oil system. A few years ago filter makers changed the filters and destroyed AC engines. Also be sure there is a tube in the center of the filter. There is a pressure regulator valve that bleeds to the filter and its spring can sometimes be adjusted.
Gerald J.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2017 at 9:16pm
And make sure the tube in the center of the filter base isn't pushed all the way down...mine was when I got it...it was often a "quick fix" to try and get some pressure built up. Pushing it down cuts off oil flow to the filter.
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2017 at 9:41pm
The filter is definitely the cheapest way to start.  Get a Fram C159 filter on it.
Heavier oil is not the answer.  It only puts off the inevitable for a little while.  I know of a dealer that puts it in tractors that they sell.  Someone I know bought a backhoe from there.  The engine seized with the hoe in a hole 11' deep!  The engine couldn't pump the thick oil in cold weather.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis Wd45 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2017 at 10:24pm
I currently have a wix 57011 filter on it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2017 at 10:30pm
That's what I use. Nothing wrong with that.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis Wd45 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2017 at 10:38pm
Ok I’m not by the tractor now when I am I’ll post a picture of the oil filter mount to see if that’s right.
Allis dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 01 Dec 2017 at 8:16am
You're right on the line of being ok or low. Like others said, most likely is your cam bearings are worn. An up to snuff oil system usually has the needle straight up between the R and M at about 15 PSI
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis Wd45 Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jan 2019 at 11:17pm
I was just reading through this post. I currently have the oil pan off the engine to change the pan gasket. How much work is required to replace the cam bearings. I'm not necessarily going to change them just curious of what all needs to be done.
WD45
IH Cub Cadet 149,1650,1250
#2 Cart, IH#2 Tiller
Don(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jan 2019 at 7:33am
The engine will need to come out to get the cam bearing changed, like this.
Edited by Don(MO) - 05 Jan 2019 at 7:36am
Brian G. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian G.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jan 2019 at 8:53am
[QUOTE=littlemarv]
______________________________________________________________
Marv, that is a clever idea!
"Normal" oil pressure on a WD/WD-45 is 12 PSI at operating temp.
Spiking to 25-30 PSI at cold start up is probably normal, especially if the oil pump and engine are in excellent condition.
Of course we all know these engines seemingly last forever with the needle barely off the pin.
Adam Stratton View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Adam Stratton Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jan 2019 at 8:05pm
Don, is that a special puller or how tricky is it for an amateur to replace? Ive got a 45 and a D14 on the list that both need that job done.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jan 2019 at 10:36pm
Adam you can install them with a cam bearing driver like this and you might rent one from the parts store, if you are thinking about trying to do them send me a PM with your phone number and I will walk you through it.
GARY(OH/IN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GARY(OH/IN) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jan 2019 at 1:28am
That 5# oil pressure on the little B's can make you money now and again. I was at an auction and bought a restored 1947 B with a Woods belly mower, L59 I think, for $850. All new rubber with the size on the bars yet hardly marked. New paint and decals, ran and drove nice, nice all the way around. It was a consignment sale and it was announced that after the rebuild it still only had 5# so the owner went and bought new. Auctioneer told me he was a city guy with alligator shoes. Next consignment sale I went to I saw a guy looking at mowers. Pitched mine and he watched the junk sell, then stopped over and bought the B for $1750. Good Enough.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis Wd45 Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jan 2019 at 4:03am
Sounds like a little more work than I’m wanting to do at the moment. I will just leave it alone since these engines seem to run fine on 5-10 Psi.
Edited by Allis Wd45 - 06 Jan 2019 at 4:07am
WD45
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis Wd45 Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2019 at 7:03pm
Looking at the pressure guage on my tractor I noticed the box that the letters are in is slightly longer than the pictures posted above. Is mine a 30psi guage or is it different since the face is slightly different?
WD45
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2019 at 7:32pm
If someone hasn't already said so, just install a known good quality 30# gauge to see what you really have for pressure.
Wink
I am a Russian Bot
This page was generated in 0.107 seconds.
