wd 45 puller starter
d17brown View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote d17brown Quote  Post ReplyReply Direct Link To This Post Topic: wd 45 puller starter
    Posted: 29 Nov 2017 at 9:17pm
anyone have luck with gear reduction starters for wd 45 with high compression
phil
allispuller View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote allispuller Quote  Post ReplyReply Direct Link To This Post Posted: 01 Dec 2017 at 3:15pm
I have a starter from HI Torque IMI out of California on mine works well just had to slide it in a little further than what they drilled the hole but other than that works just fine and cranks it over easily
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 01 Dec 2017 at 6:03pm
You don't need one of them if you have me build yours for ya. Its not cheap, but one of my units can turn any of those hi compression pullin' engines over quite well. Some of the feller's here that pull have my Starter motors on their machines for a few years now...
Steve@B&B
autobody View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote autobody Quote  Post ReplyReply Direct Link To This Post Posted: 18 Dec 2017 at 9:23pm
I have a hit torque gear reduction starter for used very little $550.00
