wd throttle arm
Sitesstables View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sitesstables Quote  Post ReplyReply Direct Link To This Post Topic: wd throttle arm
    Posted: 29 Jun 2010 at 7:24am
Ok I can move the throttle lever just fine, issue is if I push it down it jumps back up it will not stay in postion I put it in.. like a spring is super tight.. any ideas what I need to look at?
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jun 2010 at 7:50am
The spring under the gas tank maybe. I don't remember it's been so long. Also the friction block on the lever and the spring opposite to it on the other side of the quadrant.
Wink
I am a Russian Bot
Mike(SEIN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mike(SEIN) Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jun 2010 at 5:45pm
The springs on the backside of the quadrant get weak from rust. I had this same problem with my WD New springs and new friction blocks helped a lot.
BearcatnorthMN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BearcatnorthMN Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jun 2010 at 9:05pm
I haven't been able to find the springs to replace mine behind my quadrant.  I use a piece of a rubber tire about 1/4 inch thick and about 1 inch wide and a couple of inches long and just wedge it between the lever and the quadrant.  I have to hang onto it so I don't lose it when moving it but it keeps the lever tight and it doesn't drift.   Crude but effective.
This page was generated in 0.058 seconds.
