HD16 Exhaust manifold
Morten.have View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Morten.have Quote  Post ReplyReply Direct Link To This Post Topic: HD16 Exhaust manifold
    Posted: 22 Nov 2017 at 1:13pm
I have a broken exhaust manifold on my HD16DC the ingine is a 844 but I don’t know for sure.
I really bad need a new manifold, and I are of course able to fabricate a new none, but maybe some of you guys know where to find a new or a spare one. Please let me know. Thanks
CAL(KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2017 at 1:22pm
yes 844.   do not think it would be hard to locate a used one here in the US but you may be money ahead to fabricate with transport costs.  all HD16 manifolds prior to Series B with turbos are the same I believe.  early hd21 buda manifold would work as well no turbo.  I actually have 1 but don't care to sell it.
gemdozer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote gemdozer Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2017 at 4:39pm
Do you have a part number for the exhaust manifold
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2017 at 12:07am
there's a parked later model 16 (square design) with a fabricated ex manifold on it.The builder put his name on it in weld.Did a decent job.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Morten.have Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2017 at 12:42am
Can you get some pictures of that ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Morten.have Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2017 at 1:24am
I ned the complete manifold assembly.
jerbob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jerbob Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2017 at 6:10am
I will start a search Morten.
ACjack View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACjack Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2017 at 9:00am
When doing your searches be sure to include the engine series number "IE 16,000" along with what your using which is the cubic inch displacement of the engine.
There was several different exhaust manifolds that where used on the "844 cubic engine".
Post Options Post Options   Thanks (0) Thanks(0)   Quote jerbob Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2017 at 9:13am
Thank you and good suggestion.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Morten.have Quote  Post ReplyReply Direct Link To This Post Posted: 24 Nov 2017 at 3:02am
Thanks all off you 👍🏻
I hope I can find one, my google search have not been very helpful yet
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 24 Nov 2017 at 10:54am
I can take a pic next time I'm there but no way of knowing when that will be.It's next to a place I deliver seed to but I don't do the scheduling. Will have to get someone to accept texted photo and put on here. It's in Walnut Grove IL a little N/E of Macomb.
Edited by SteveM C/IL - 24 Nov 2017 at 10:59am
Post Options Post Options   Thanks (0) Thanks(0)   Quote jerbob Quote  Post ReplyReply Direct Link To This Post Posted: 25 Nov 2017 at 9:21am
So far no luck on my search. I have my local Agco shop looking at old dealer inventories as well.
I have a crack on my center section of my exhaust manifold but I'm going to take it off clean it out and braze it when ready. My dealer was able to get me all new gaskets, studs and connection rings new. Still looking for you .
Ian Beale View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ian Beale Quote  Post ReplyReply Direct Link To This Post Posted: 25 Nov 2017 at 3:02pm
Re fixing that crack.
Have a look at the Lincoln application dodger for Ferroweld for repairing things like cast iron manifolds.  Went into some detail last time I looked.
A very hard electrode to find in Australia.  A neighbour has a supply and he's repaired the exhaust manifold on our truck exhaust successfully.  It was mentioned for antique vehicle repairs as it rusts like the original whereas nickel repairs don't.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Morten.have Quote  Post ReplyReply Direct Link To This Post Posted: 26 Nov 2017 at 3:39pm
Mine is not fix able
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ian Beale Quote  Post ReplyReply Direct Link To This Post Posted: 26 Nov 2017 at 4:29pm
Straight stacks and a good set of ear protectors then?
Post Options Post Options   Thanks (0) Thanks(0)   Quote jerbob Quote  Post ReplyReply Direct Link To This Post Posted: 26 Nov 2017 at 7:40pm
Oh man,, straight pipes would be ear killers for sure Ian. Would be fun to hear it though.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jerbob Quote  Post ReplyReply Direct Link To This Post Posted: 26 Nov 2017 at 7:41pm
Looking still Morten.
Post Options Post Options   Thanks (0) Thanks(0)   Quote gemdozer Quote  Post ReplyReply Direct Link To This Post Posted: 27 Nov 2017 at 1:52pm
I have a complet exhaust manifold but not the same parts number.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jerbob Quote  Post ReplyReply Direct Link To This Post Posted: 27 Nov 2017 at 6:45pm
What are the numbers for your manifold gemdozer?
Post Options Post Options   Thanks (0) Thanks(0)   Quote jerbob Quote  Post ReplyReply Direct Link To This Post Posted: 27 Nov 2017 at 8:20pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote gemdozer Quote  Post ReplyReply Direct Link To This Post Posted: 28 Nov 2017 at 5:05am
The exhaust manifold parts number are
center 4367606
left     4365831
right   4366306
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACjack Quote  Post ReplyReply Direct Link To This Post Posted: 28 Nov 2017 at 8:24am
Just a reminder: Just because a number is cast into a part doesn't mean that is the part number, it could be just a "casting" number and the actual part number could be something else.
AC would sometimes use the same casting for different multiple parts.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jerbob Quote  Post ReplyReply Direct Link To This Post Posted: 28 Nov 2017 at 12:32pm
Agreed.
My HD16DC has an engine number of 4393hdc. My same 3 sections of exhaust manifold with parts numbers from my owners parts manual that came with the machine, are different than those listed by our good friend gem dozer.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Morten.have Quote  Post ReplyReply Direct Link To This Post Posted: 28 Nov 2017 at 4:25pm
What are your asking price for it?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Morten.have Quote  Post ReplyReply Direct Link To This Post Posted: 02 Dec 2017 at 4:10am
I’m still looking for a exhaust manifold for my HD16DC 844 engine. The one Gemdozer has is unfortunately broken
Please let me know if you have one guys
Ferdinand View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ferdinand Quote  Post ReplyReply Direct Link To This Post Posted: 02 Dec 2017 at 7:32am
Can you post a picture of your broken manifold? I'm curious how bad it might be.
Because narrow is the gate, and narrow is the way, which leads unto life, and few there be that find it.
Mathew 7:14
Post Options Post Options   Thanks (0) Thanks(0)   Quote jerbob Quote  Post ReplyReply Direct Link To This Post Posted: 02 Dec 2017 at 5:35pm
Sorry Gemdozer's manifold didn't work out Morten.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Morten.have Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2017 at 3:28pm
there are 3 holes one in each manifold piece. All 3 holes are about 1x1 inch
Post Options Post Options   Thanks (0) Thanks(0)   Quote jerbob Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2017 at 3:59pm
That's pretty bad for sure Morten.
Afraid I am not much help other than to continue to look here in the states for ya.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ferdinand Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2017 at 5:13pm
This might be a difficult solution but, ...
A couple of years ago I was going to make a custom exhaust system for car. A local company said they could waterjet cut a 3/8" thick steel flange for the header pipes.
I was going to use a tube bender and have the local welding shop make the pipes and weld them to the flange. Quoted cost of the one-off waterjet flange was "less than a hundred dollars".
The welder would charge about $250.00
P.S. Somewhere on Youtube there is a video of a guy making a simple custom exhaust for an International dozer. He took a big steel pipe and made a "log" runner style exhaust.
Edited by Ferdinand - 03 Dec 2017 at 5:15pm
Mathew 7:14
