WD45 Hydraulics and Steering
Runamuck View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Runamuck Quote  Post ReplyReply Direct Link To This Post Topic: WD45 Hydraulics and Steering
    Posted: 21 Nov 2017 at 7:22pm
Have a tractor in the shop that needs leaks fixed on the hydraulic pump and valve. Ordered a bunch of other parts from Steiner, but don't see any of this in the catalog. Where can I find seals, o-rings, etc to fix these leaks, and a gasket for between pto gearbox and trans? I also have to put on pwr steering he took off another tractor. Anything special I need to know? Thanks.
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 21 Nov 2017 at 8:53pm
Your local AGCO dealer should have those items.
Albert View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Albert Quote  Post ReplyReply Direct Link To This Post Posted: 21 Nov 2017 at 9:01pm
I can help you with the pump gaskets o rings and seals but would recommend you replace the balls and springs also. we also have the pto gasket. 660-582-5150
Albert
