175 Wiring
LYNNMN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LYNNMN Quote  Post ReplyReply Direct Link To This Post Topic: 175 Wiring
    Posted: 20 Nov 2017 at 5:14pm
all new wiring and everything seems to work when check lights all work. When I start tractor fuse for lights blows. I can't figure which wires are wrong to cause this hooked wires same as old. What am I missing. Thanks for any advise.
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 20 Nov 2017 at 8:41pm
What size is the fuse?  Should be 20 amps.  IF any extra lights were added, the extra load will blow the fuse.  Used to happen on our 175 before we removed the extra non-original lights.
If not, check to see that it's not grounding out anywhere.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 20 Nov 2017 at 8:56pm
Unplug them before they go up into finders. If ok, unhook each light one at a time.    MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote LYNNMN Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2017 at 5:06pm
It is 20 amp fuse and no extra lights only 2 head lights not 4. If it is short why does it not blow fuse when tractor is not running
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2017 at 8:27pm
It's not going to short out when there is no current flowing through the wires.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2017 at 9:35pm
A wire is bare some where, causing it to ground from vibration with motor running.
Had a similar problem with oil lift. Would come on past 1/2 throttle. Wire was pinched under hood. Grounded from vibration.     MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote LYNNMN Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2017 at 10:15am
I understand there is no current when light switch is not on. I can turn on lights and they work and do not blow fuse. When I start tractor and turn lights on fuse blows. Sorry if I am not clear. Thanks for all help. I will try to work on it tomorrow.
Post Options Post Options   Thanks (0) Thanks(0)   Quote LYNNMN Quote  Post ReplyReply Direct Link To This Post Posted: 24 Nov 2017 at 3:55pm
Does anyone have a wiring schematic other than what is in tractor manual. a service manual if it is different. I am having a hard time following book that came with tractor
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 25 Nov 2017 at 3:54pm
they are telling you that vibration from running engine make the short show up.Turn em on with dead engine and start banging on parts and see if same result
Post Options Post Options   Thanks (0) Thanks(0)   Quote LYNNMN Quote  Post ReplyReply Direct Link To This Post Posted: 25 Nov 2017 at 7:49pm
Thanks for all feedback found problem and it is working great now. When I rewired tractor 2 wires were switched around. 2 wires go to key and 2 wires go to start button had them reversed so it always blew fuse.
drobCA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote drobCA Quote  Post ReplyReply Direct Link To This Post Posted: 25 Nov 2017 at 9:05pm
you're sure not the first to do an "oops" on the rewiring.
don't even ask how I know that. Confused
glad you worked it out.
3 Ford 8N's I loan to neighbors, but the '52CA, '41B and little B1 I do not.
This page was generated in 0.480 seconds.
