HD 11E Brake Adjustment
HD11E View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD11E Quote  Post ReplyReply Direct Link To This Post Topic: HD 11E Brake Adjustment
    Posted: 19 Nov 2017 at 8:23pm
Just inherited an HD 11E. Been sitting a while but fired right up. Having an awful time on adjusting the brakes. I've got the brake cover plate off but now not sure what to do. I see the 1 bolt ( brake adjustment bolt?) that floats around a little but appears to not turn. ( ceased?)   I guess my question is where to begin?    How much grease should I pump into the brake zerks, etc..? Any brake adjustment knowledge is appreciated.
Lazyts View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lazyts Quote  Post ReplyReply Direct Link To This Post Posted: 19 Nov 2017 at 8:45pm
Early (dry brakes)
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lazyts Quote  Post ReplyReply Direct Link To This Post Posted: 19 Nov 2017 at 8:46pm
Late model (wet brakes)
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD11E Quote  Post ReplyReply Direct Link To This Post Posted: 19 Nov 2017 at 9:22pm
thx lazy...i can see i have an early model ( dry ) will see how far i can get!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 20 Nov 2017 at 5:46am
They are at least relatively easy to remove the adjusters as on my 7G to free them up with the large covers open.
gemdozer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote gemdozer Quote  Post ReplyReply Direct Link To This Post Posted: 20 Nov 2017 at 5:29pm
YOU should have 1 3/4 inch to 2 inchs free travel on top brake pedal for good adjustement
