B side weights
DaveWisc. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveWisc. Quote  Post ReplyReply Direct Link To This Post Topic: B side weights
    Posted: 14 Nov 2017 at 3:30pm
Do the weights that bolt on the side of the engine have a spacer on the inside of the bolt or not. I am in the mode of buying weights and want to know how they are mounted. Thanks Dave
Hubnut View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hubnut Quote  Post ReplyReply Direct Link To This Post Posted: 14 Nov 2017 at 5:40pm
Dave,
I don't have my parts book handy, but there is a bolt that goes through the front engine plate.  That bolt holds a fitting of larger diameter that the front of the weight slides into this.  I've used a pipe if you can't find the fitting.
Steve
1940 B "Lucy"
1941 B w/ Woods L59 "Flavia"
1942 B w/ finish mower "Dick"
1941 C w/ 3-point "Maggie"
1947 C SFW w/ L306 "Trixie"
1972 314H
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 14 Nov 2017 at 6:09pm
Like hubnut says for the front: hex head bolt, lock washer, and spacer.
At the rear: hex head bolt and lockwasher.
