What would a c pull (qustion 2)
Wdtractorman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wdtractorman Quote  Post ReplyReply Direct Link To This Post Topic: What would a c pull (qustion 2)
    Posted: 04 Nov 2017 at 7:54pm
I asked the other day about weighting up a c to use it. I got pretty much the answer that I'd came up with myself, if you can get enough on it it would do the job. The job was pulling some leftover h farmall equipment, mostly a rope trip subsoiler.
   Anyway new question is how much weight can you add to a c and still use it without damaging anything? My thoughts was I found a set of the heavy cast wheels centers and iv got a set of avery rear wheel weights put them on and a set of frame weights when I find them. Is that about all a guy could get away with or could you add some?
    Thanks, Wil
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hubert (Ga)engine7 Quote  Post ReplyReply Direct Link To This Post Posted: 04 Nov 2017 at 8:20pm
Frame weights or engine side weights? The side weights will be fine as will the wheel weights and those should be enough. I would be careful putting any type of frame weights on a C.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 04 Nov 2017 at 8:20pm
A C is about the same weight as a CA, and we know what a CA can pull...
[TUBE]NGV3UuqlX3o[/TUBE]
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wdtractorman Quote  Post ReplyReply Direct Link To This Post Posted: 04 Nov 2017 at 8:31pm
And set of engine weights. I couldn't think of exactly what to call them. I know a ca will really surprise you pulling mounted equipment. I had a ca and a h at the same time I could pull 2 14s with both and a 7 ft disk with both. Only difference is the ca had mounted SC equipment. The ca would probably pull my drag disk but it wouldn't the plow or the subsoiler I tryed. But I'm sure it would have weighed up.
DSpears N IL View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSpears N IL Quote  Post ReplyReply Direct Link To This Post Posted: 04 Nov 2017 at 9:11pm
My CA with front & rear wheel weights plus engine side weights!
DeWayne
Dick L View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 05 Nov 2017 at 11:56am
All the weight you can stack on the wheels will not cause any problems as long as the tires will hold the weight.
Like I said before, Dad had his tires loaded with two C wheel weights on each wheel, side engine weights both sides and a plank across the drawbar with sand bags on both sides behind the final drives as high as the top of the final drives. He farmed 148 acres of rolling hilly clay on the farm that laid in Ohio, Indiana and Michigan. Nothing broke because of the weight. I would guess the tractor weighed close to 4000 pounds. I pulled my C in the 3500 class some and the rear tires were not loaded. I used three sets of wheel weights with loaded front tires and used a CA front to add a hunk of steel as an extra front weight. I also cut bars of hot roll to stack under the seat to make heaver weights.
weighted to 3000 pounds in the picture.
My narrow front B weighted to 3000 pounds.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wdtractorman Quote  Post ReplyReply Direct Link To This Post Posted: 05 Nov 2017 at 8:56pm
Dick I'm glade you replied. I though that what you had said. How much dose a c weight weigh? I think those avery weights are around 100 lds a can just barely handel them by hand.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 06 Nov 2017 at 6:31am
I pulled my C one time in a 2500 pound class before modifications. My memory is not recalling the shipping weight at this moment.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wdtractorman Quote  Post ReplyReply Direct Link To This Post Posted: 06 Nov 2017 at 3:49pm
I'm sorry. I ment the weight of the actual wheel weight?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 06 Nov 2017 at 4:50pm
I guess it should be my sorry. I put my own meaning to what you wrote.
The tapered C weights are 100 pounds each. I have them on the inside and outside of the wheel. 200 pounds on a side. I have studs sticking out to put the third set on. The weights on the B are 125 pounds each that you see in the picture. Using pipe spacers and washers you can use those on a C as well. the holes line up.
I also add a C weight to the B when I needed the extra weight.
Edited by Dick L - 06 Nov 2017 at 4:59pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wdtractorman Quote  Post ReplyReply Direct Link To This Post Posted: 06 Nov 2017 at 5:38pm
Those cone shaped weights look very simular to my avery weights. I have 3 avery weights and one off a b farmall so I could put them on inside and out I guess.
This page was generated in 0.273 seconds.
