NH 467 Haybine
wayne3 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wayne3 Quote  Post ReplyReply Direct Link To This Post Topic: NH 467 Haybine
    Posted: 27 Jun 2010 at 6:17am
 Interested in proper roller adjustment.Looks like adjustment bolt underneath,in center. Which way should I turn it and how do I tell if its right. When I check the cut hay, I can't tell if rollers are working properly. What should I look for? Thanks for any advice.
allisorange View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote allisorange Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jun 2010 at 6:55am
          If your talking about tension on the rollers there is a crank on both sides for that. If you mean lining up the rollers there is an adjustment on the bottom sprocket that has 4 bolts that you loosen and line up rollers so they do not touch when running. That is the way are 469 is and I would think the 467 would be the same.
                                                    John Carlson
                                                    U P of MI.
Ken McGregor View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ken McGregor Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jun 2010 at 5:57pm
I was always told that you hold a stem of timothy or alfalfa upright by the bottom of the stem. It should bend over at the "bruises" but NOT break off. That is a rough measure of the right roll pressure but it seems to work well
regards,
Ken McGregor
This page was generated in 0.050 seconds.
