Anyone know what year this could be?
denco5 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote denco5 Quote  Post ReplyReply Direct Link To This Post Topic: Anyone know what year this could be?
    Posted: 26 Jun 2010 at 7:16pm
norm [ind] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote norm [ind] Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jun 2010 at 9:44am
  1960,S    ERA
Calvin Schmidt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jun 2010 at 1:46pm
 It's a little hard to see but it looks like it has the A-C 2200 diesel engine. That being the case it is a 1970-1975 model. The main power train is still based on the D-15 farm tractor.
Post Options Post Options   Thanks (0) Thanks(0)   Quote denco5 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jun 2010 at 4:00pm
Calvin, It does say 2200 on a plate attached to the engine, would that confirm it is an AC 2200 engine?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jun 2010 at 7:18pm
There should be a plate on the engine that says model 2200.
The serial number should be stamped on the bellhousing on the far side. That would be the right side if you are sitting on the seat.
Post Options Post Options   Thanks (0) Thanks(0)   Quote denco5 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jun 2010 at 7:41pm
Calvin, I found a stamped number on the right side bell housing. It reads 600 701?(6 or 8 I think and then FLD
Would this be the serial number?
Dennis
I am trying to get a water pump for this thing and have had no luck
This page was generated in 0.342 seconds.
