5hp scamp engine problems |
Orange4ever
Joined: 01 Sep 2014 Location: Farmington, MO Points: 390 |
Topic: 5hp scamp engine problemsPosted: 29 Oct 2017 at 11:45am |
Our B&S 5 hp engine on our Scamp is smoking and running rough. We've change the diapham seal, cleaned the carb, to no avail. When we take a air gun to the carb when running and lightly blow air into it, it clears up and runs right. What are we missing here? Thanks, Tom.
If you want a man to be a successful farmer, give him a Allis Chalmers tractor. If you want him to be a successful mechanic, give him a John Deere
jaybmiller
Joined: 12 Sep 2009 Location: Greensville,Ont Points: 25158 |
Posted: 29 Oct 2017 at 2:28pm |
toooo rich ?
adding air would lean the carb out a bit I'd turn the mixture screw in 1/2 turn see what happens... Jay |
Orange4ever
Posted: 29 Oct 2017 at 6:15pm |
We have done so and no change.
Tracy Martin TN
Joined: 11 Sep 2009 Location: Gallatin,TN Points: 10920 |
Posted: 29 Oct 2017 at 7:01pm |
Worn valve guides. HTH
Orange4ever
Posted: 29 Oct 2017 at 8:11pm |
Start on first or second pull
HudCo
Joined: 29 Jan 2013 Location: Plymouth Utah Points: 4062 |
Posted: 30 Oct 2017 at 9:44am |
bet the valve train needs to be worked over
Orange4ever
Posted: 15 Nov 2017 at 7:31am |
Put a second diaphragm in it found a small piece of sand in the jet runs good now
HudCo
Posted: 15 Nov 2017 at 8:32pm |
good thats was it i think those scamps are kinda cool
