What Do You Make of This? (Off Color)
Slim View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Slim Quote  Post ReplyReply Direct Link To This Post Topic: What Do You Make of This? (Off Color)
    Posted: 27 Oct 2017 at 5:34pm
Can any of you guys offer some insight on what I'm looking at here? On the left side of the engine there appears to be a hole in the block or plug missing and on the right hand side, the engine appears to be separated from the torque housing. Is it as bad as it looks, or am I seeing things?
http://www.auctiontime.com/listings/farm-equipment/auctions/online/22004705/new-holland-ts115a
-Slim
Edited by Slim - 27 Oct 2017 at 5:57pm
AC 1971 170 WF Gas, AC 185 Diesel WF, AC WD NF, AC '54 WD45 NF, AC 7080, AC 7030, Wheel Horse D-180 Automatic
Gatz in NE View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gatz in NE Quote  Post ReplyReply Direct Link To This Post Posted: 27 Oct 2017 at 5:49pm
too many HyperText Transfer Protocol headings
either
http:// or https://  but not both
If you plugged a link into the post, look at the left side of the box; there's already an http://
So, when you paste your link, there's another one put in.
You have to move the cursor to the left of the link you put in (on the right side) and delete the http:// or https://
The preview should show the correct link.  You can check it out prior to posting.
gatz
Edited by Gatz in NE - 27 Oct 2017 at 5:51pm
Slim View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Slim Quote  Post ReplyReply Direct Link To This Post Posted: 27 Oct 2017 at 5:57pm
Fixed it. Thanks for pointing it out.
-Slim
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 27 Oct 2017 at 6:07pm
It appears that possibly a fuel pump was removed from the left side,
and the starter was broken from the housing on the right side.
Ad states it was rolled over.
Gary
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 27 Oct 2017 at 6:16pm
I think it is worse than you envision.
The hole on the left side looks like a mounting for a camshaft driven fuel pump. If the engine was running oil would be pouring out of there.
The back flange on the other side looks like part of the flange for the starter has been broken off, so there's no mounting for the starter. There's no simple fix for that short of a replacement block.
Gerald J.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 27 Oct 2017 at 7:13pm
New Holland TS115A Cab Tractor:
* not running, sold as is where is
- 6 cyl diesel engine, 115 hp
- 2 wd
- rear 3pt hitch
- rear 540 rpm
Former county owned tractor, rolled over as pictured.
We can load no problem free of charge.
Please see pictures and/or video for complete details.
All of our items are subject to a basic limited inspection on level ground here at our facility.
Inspections are limited to our personal visual experience at the time of inspection.
This is a no reserve auction. This item sells to the highest bidder.
We can load on anything.
Sold as-is with no warranty or guarantee.
Scroll down on the listing, to see the above^^^^Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 27 Oct 2017 at 9:27pm
yep...after the roll over, that county robbed parts off it.
JohnCO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnCO Quote  Post ReplyReply Direct Link To This Post Posted: 27 Oct 2017 at 11:43pm
Ahh, a couple quarts of JB weld and a starter and stuff and she'll be cherry!
Allis Express participant
