Shovel Control Valves
LostDog88 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LostDog88 Quote  Post ReplyReply Direct Link To This Post Topic: Shovel Control Valves
    Posted: 26 Oct 2017 at 9:45am
I have the Simplicity/Allis 9020/720 and the boom on the backhoe is drifting when I release the stick. It has 6 sticks to control everything.
I want to swap out this old control valve.
Anyone know what I should be "googling" to find a replacement?
rustydollar View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rustydollar Quote  Post ReplyReply Direct Link To This Post Posted: 26 Oct 2017 at 9:57pm
6 Bank motor spool valve
Post Options Post Options   Thanks (0) Thanks(0)   Quote rustydollar Quote  Post ReplyReply Direct Link To This Post Posted: 26 Oct 2017 at 10:12pm
Or you could replace the spools with electrically operated then install a joystick for ease of control.
With electric spools your dealing with wires from the joystick, keeps things neat and tidy.
http://www.oemoffhighway.com/operator-cab/operator-interface/joysticks/operator-interface/product/10257375/danfoss-danfoss-power-solutions-formerly-sauerdanfoss-js7000-joystick
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 27 Oct 2017 at 5:39pm
First off is the drift from valve body or a internally leaking cylinder - drift is generally when pressure is unequal between ends of piston and fluid on back side of movement direction - so a void or open flow no non pressure return side  - bypass of packing is another thing
