CA traction booster
kenbob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kenbob Quote  Post ReplyReply Direct Link To This Post Topic: CA traction booster
    Posted: 25 Oct 2017 at 8:14pm
I am trying to set the traction booster on the CA I just bought.  The big spring was slack, so I got that set.  I cannot get the locknuts loose on that shaft that runs back to the pump on the upside of the hitch bracket. If I could get it off, I could get it on a vice. I thought if I took the screw out at the end, I could just pull the whole thing out.  The shop manual only shows a spring on the shaft down side of the bracket, but it does not want to budge when I try to pull the whole thing out.  It turns in the bracket so it isn't rusted in or anything.  The shop manual I have is a little short on detail, I think.
Post Options Post Options   Thanks (0) Thanks(0)   Quote kenbob Quote  Post ReplyReply Direct Link To This Post Posted: 27 Oct 2017 at 9:15pm
I found that pin and got it apart.
