Windshield Washer Fluid as Tire Ballast
CrestonM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Topic: Windshield Washer Fluid as Tire Ballast
    Posted: 23 Oct 2017 at 6:54pm
Does it work well? I see my local Napa has it for $1.99 a gallon, so I thought I may buy a bunch of it and use it as tire ballast in my B, if it's non-corrosive. There are no tubes in the rear tires, oddly enough.
I wouldn't think it would harm anything, being windshield washer fluid, but I figured I'd better ask first.
I've thought about Rim Guard, but that costs more. I realize it has greater mass, but I'd rather save some money and give up a few pounds. Just need to add some more weight so I'm not burning so much rubber when plowing. I've already got 90# weights in each rear, plus the belly sickle mower.
Thanks!
Post Options Post Options   Thanks (0) Thanks(0)   Quote TimNearFortWorth Quote  Post ReplyReply Direct Link To This Post Posted: 23 Oct 2017 at 7:27pm
RV anti-freeze may work for you. Not the cheapest and you still need to check how low it will go ambient temp wise. Any RV center should have it in stock this time of year.
cnafarms View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cnafarms Quote  Post ReplyReply Direct Link To This Post Posted: 23 Oct 2017 at 8:45pm
I have windshield fluid in 2 of my tractors. you should be fine espically if u have the rear cast iron weights as well. Don't know bout not having no tubes. Both mine have tubes in them. I'd ask napa if they sell it by the 50 gallon drum winter blend. I got it like that before from them. Much easier. My 2 cents worth
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 23 Oct 2017 at 9:20pm
Thanks. I'll ask them about that. Maybe it'll be cheaper buying in bulk.
marion View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote marion Quote  Post ReplyReply Direct Link To This Post Posted: 24 Oct 2017 at 5:33am
I put windshield washer fluid in one of mine, afterwards was at tire shop and ask about ballast. they use methyl alcohol. ended up cheaper to have them do it. I think methyl alcohol is an ingredient in washer fluid
Stan IL&TN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan IL&TN Quote  Post ReplyReply Direct Link To This Post Posted: 24 Oct 2017 at 7:18am
I have it in the front tires of my riding mower if that counts.  Big smile
1957 WD45 dad's first AC
1968 one-seventy
1956 F40 Ferguson
Tbone95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 24 Oct 2017 at 7:22am
Windshield washer fluid is pretty much methyl alcohol, yes.
Sure it will work OK.  Like you said, you give up a few pounds.  I don't know if it would be totally non corrosive?  With no tubes?
steelwheelAcjim View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote steelwheelAcjim Quote  Post ReplyReply Direct Link To This Post Posted: 24 Oct 2017 at 8:25am
Had M.E. Miller Tire in Wauseon, Oh (a forum member) fill 18.4 X 30 tires on a tractor I have. No issues at all. Was told only about a pound less than calcium chloride in weight difference.
Pre-WW2 A-C tractors on steel wheels...because I'm too cheap to buy tires!
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 24 Oct 2017 at 8:37am
pound per gallon
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 24 Oct 2017 at 8:40am
That one pound per gallon didn't seem right to me, just googled windshield washer fluid, only about 6.84 pounds per gallon.  Rim Guard was 10.7-11.0 pounds per gallon.  Isn't CaCl about 10 something?  Depending on concentration?
*edit* at 30%, CaCl =~10.8 pounds per gal.
Edited by Tbone95 - 24 Oct 2017 at 8:44am
HoughMade View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HoughMade Quote  Post ReplyReply Direct Link To This Post Posted: 24 Oct 2017 at 9:32am
An alcohol/water mixture in direct contact with steel rims?  Count me out.  In tubes, I could see it.
Edited by HoughMade - 24 Oct 2017 at 10:20am
1951 B
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 24 Oct 2017 at 10:19am
Come to think of it, I don't think I paid a whole lot more than $2 per gallon of the new "corn juice" they're selling for ballast.
DougS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 24 Oct 2017 at 11:07am
Water is about 8.5 pounds per gallon. I would think that alcohol is slightly less than water.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 24 Oct 2017 at 1:30pm
If that's the case, me too. Don't want to rust my rims out.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 24 Oct 2017 at 2:05pm
Unless you have a good dryer on your air supply, there is bound to be some water inside a tire. Adding a bit of alcohol ain't gonna hurt the rim. Probably the worst hing could happen is it could start to rust if you leave air space in it and leave it set in one spot for a LONG time.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 24 Oct 2017 at 2:09pm
But CTucker, you have to leave some airspace in it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 24 Oct 2017 at 2:17pm
Not enough to let the rim get air to it!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 24 Oct 2017 at 2:25pm
OK, I guess I'm not sure what you mean then, my bad.  When my tires get filled with anything, they are about 75% full....there about.  I can park the tire valve stem at 12:00 and check pressure without a sealed gauge and without losing fluid.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 24 Oct 2017 at 2:37pm
I guess I'm a little confused as well.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 24 Oct 2017 at 10:31pm
The alcohol might not hurt the rim, but the water will. Windshield washer fluid is not straight alcohol, but a water and alcohol mix.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 25 Oct 2017 at 7:00am
Right brian.  That isn't the part I was confused about...IDK about Creston.  Oh well.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 26 Oct 2017 at 12:36pm
When they say 75% full, just picture the tire on the tractor as a water tank filled 3/4 of the way to the top. From there you inflate the tire with air to how ever much air pressure you need. Was that what you guys were wondering?
Edited by Brian Jasper co. Ia - 26 Oct 2017 at 12:38pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 26 Oct 2017 at 1:10pm
I'm confused about what Charlie said...about getting all the air out of the tire. How would you fill it past the valve stem without it all running back out when you went to put the core in?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Oct 2017 at 1:22pm
The part about the air not getting to the rim, when only 75% full....for me.  If fluid doesn't come out of my valve stem at 12:00, then there's air to steel in that area.  It may be such that it would take years to corrode, if at all, but still....(IMO)
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 26 Oct 2017 at 1:32pm
Maybe I'll just look for more iron to bolt on. Seems that would be easiest.
Or fork out the extra $$$ for Rim Guard. Then I know they wouldn't rust.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Oct 2017 at 1:42pm
Or fork out the extra money for a tube.
I just had to replace a rim on my 7045.  I've had to have 2 other rims repaired on tractors over the years for rusting out.  So I will be staying away from anything possibly corrosive, because it not only is expensive to fix all that, it likely puts you "down" when you need it the most.
Anyway, not knowing any better, I asked for rim guard.  The guy told me, well, they went to beet juice (rim guard) because the CaCl rusts out rims.  Then they found out the beet juice is taking out valve cores. (Which ain't nearly as bad, but still a pain).  Now we have "corn juice".  That's all the receipt said, corn juice, so I don't know if it's still made by rim guard or something else, about $2.00 per gallon.  Just fyi.
Allis dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 26 Oct 2017 at 3:11pm
Locally here, the RimGuard dealer sells rim guard for $3 a gallon
