Any one seen a mower set up like this?
Wdtractorman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wdtractorman Quote  Post ReplyReply Direct Link To This Post Topic: Any one seen a mower set up like this?
    Posted: 23 Oct 2017 at 6:02pm
I though it was pretty neat. It be a lot easier to take off and on than the bell mower on the b.
wfmurray View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wfmurray Quote  Post ReplyReply Direct Link To This Post Posted: 23 Oct 2017 at 6:23pm
Look like a farmall super A with pto on left side.
EricPA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote EricPA Quote  Post ReplyReply Direct Link To This Post Posted: 23 Oct 2017 at 6:29pm
looks like a cobbled up mess. the 3 point tower was laid forward and a tongue hitch welded to it and the braces that should go back to stabilize the upright are laid forward to brace against the farmall hitch
Life is tough,but it's tougher when you're stupid. - John Wayne
Dnoym N. S. Can. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dnoym N. S. Can. Quote  Post ReplyReply Direct Link To This Post Posted: 23 Oct 2017 at 6:39pm
look like the bush hog finishing mower
with the three blade
on a farmall cub with pto on left side
B:-)        Dnoym
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 23 Oct 2017 at 7:24pm
Just bought a 2015 Landpride rototiller, It gots moveable lower 3 point brackets, to off-set it, if you want.  As long as the drive line aint kinked harder than 25ยบ, the manual says its OK...Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 23 Oct 2017 at 8:01pm
setup to cut offcenter to one side...Works good in some areas... Also the 3 pt use as a TOW BAR is a good idea since the tractor is too small to lift the deck with a 3 point....... basically a drag type mower.. .Probably works good in weekly / monthly mowed yard.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wdtractorman Quote  Post ReplyReply Direct Link To This Post Posted: 23 Oct 2017 at 10:45pm
Yeah its a farmall supper A. I was on ebay looking for forks for my caroni finish mower and seen it. I just thought it be something that could be adapted to the b, only my mower a 5 ft and this one is a 6 so it would have to be inline with the tractor instead of offset. I was just wondering if anyone has actually used something like this? Iv seen a two of these set ups know (both was farmalls) one was a land pride and said it was a factory set up.
    Like I said it looks like it be easier to remove for using my b for something other than mowing. My 306 woods isn't hard to remove. It just takes me about 10 mins as long as I leave the brakets on the tractor, but it seems to take a while of tinkering with things to get it back to mowing just right.
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 24 Oct 2017 at 7:53am
I don't see a problem with it. I use a 6' farm King on my CA and never hook up the top link. So it just follows along behind. It's got 4 guage wheels just like the mower in the picture. I can't lift my farm King it's to heavy for the CA but follows along and mows just fine
Post Options Post Options   Thanks (0) Thanks(0)   Quote wfmurray Quote  Post ReplyReply Direct Link To This Post Posted: 24 Oct 2017 at 11:59am
I have a caroni behind my B ,59 inch and works o k . It is a finish mower not a bush hog.Agri supply sells caroni and parts.
Phil48ACWC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Phil48ACWC Quote  Post ReplyReply Direct Link To This Post Posted: 26 Oct 2017 at 6:35am
I guess that's what you have to do without a 3 point hitch. It could be centered behind the tractor easy enough but it would put the u joints at a lot more angle.
