46 C w/magneto help
CAL(KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Topic: 46 C w/magneto help
    Posted: 23 Oct 2017 at 8:33am
I have a 46 C im trying to get going and the damn thing just wont stop fighting me.   iv had it running but it just runs like crap.  When I have the tractor on #1 compression,  the mag drive slot is not horizontal.  I tried to mess with the rotor timing in the mag but it either does nothing or sputters badly.  I am cranking the tractor with a starter and the mag has good spark.  I have pulled the mag about 17 times trying to get things lined up.  I don't have a hand crank so lining up #1 compresson is a pain using the belt and fan.
Can I assume correctly that no amount of changing the rotor timing in the mag is going to fix it because the impulse is not happening at the correct time and ill have to pull the cover and retime the governor gear?   Thought at first I had a carb issue as it would start and run but poorly and the tank was full of junk.  Cleaned the tank and rebuilt the carb (it was full of rust and gunk) and same problem so started on the mag.
Edited by CAL(KS) - 23 Oct 2017 at 4:05pm
Bill Long View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill Long Quote  Post ReplyReply Direct Link To This Post Posted: 23 Oct 2017 at 3:32pm
If you impluse spring is broken - that is when you turn it over mounted in a vice you do not hear a click - they you are at least 180 degrees out of time.  You may want to send it to a shop for repair.  Steve at B&B is a sponsor on this site.  He will have the parts and the knowledge to fully repair your mag.  Perhaps you can find a more local mechanic.
In any event hope it comes out well.
Good Luck!
Bill Long
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 23 Oct 2017 at 3:35pm
I have a good magneto on a running engine that I'll sell for $120 plus the shipping.
Dick L View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 23 Oct 2017 at 5:47pm
I always test a magneto in a vise using a spark plug wire from the cap and watching the spark from the wire end to the magneto case. I make sure I have a good spark from each wire. Without a hand crank you can find the compression top dead center by removing the valve cover and make sure both rocker arms are up with a gap under both valves. I find it easier to back the engine up to where the magneto drive will line up without having tension on the impulse spring. Make sure the next time the impulse snaps it is going to fire number one plug wire before mounting the magneto. I do this in the vise when testing for spark then tape the drive so it can not turn backwards. It can turn back all day long and you will not know which wire it will fire on after mounting.
saele View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote saele Quote  Post ReplyReply Direct Link To This Post Posted: 24 Oct 2017 at 7:16am
You can remove the mag gear by removing the small screw that locks it in. Seems to me I had to move my gear on my C one notch to get it in the right gear slot and bring it horizontally. It is irritating that I can't remember anything anymore, I just did this to my C this Spring and have forgotten the details. I am now asking myself why I didn't have the gear lined up correct in the first place. I am in the golden age you know.
Take a look at it and also your manual.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 24 Oct 2017 at 7:42am
Guys, the mag is working fine.  My issue is I was treating it like a distributor, trying to line up the rotor when the engine was on #1 tdc.  I guess I came to the realization that since the mag drive slot it not horizontal on #1 tdc,  the inpulse action of the mag would not be timed correctly and thus the reason im having trouble.  Correct?  what im saying is,  since the governor gear is not timed correctly,  it would cause the impulse to trip at the wrong time even if I have the rotor on #1.
I think I have answered my own question, but im just trying to verify my line of thinking is in the right direction.  if it was a distributor,  actual rotor positon does not technically matter, but in a magneto it has to correlate with the impulse.
Post Options Post Options   Thanks (1) Thanks(1)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 24 Oct 2017 at 8:34am
The governor gear "must" be timed horizontal at top dead center on the compression stroke as in the picture below. You can check this with the TDC or CENTER line in the center of the inspection hole.
In the vise is where you can snap the impulse and watch for the spark to know when the gears are lined up properly. If you gear has the marking on then you need to engage the C over the taper tooth on the small gear.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 24 Oct 2017 at 8:39am
Yes.  Thank you.  I thought so, just needed to verify.  All I have for model c is IT manual and as you know they don't show jack.  Apparently this is why the PO never got it running after he bought it.  Can the governor gear be retimed by removing the cover or does the entire front plate need to come off?
Post Options Post Options   Thanks (2) Thanks(2)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 24 Oct 2017 at 10:09am
You can pull the gear out the front after the governor housing has been removed on the B and C's. Make sure the piston is at top dead center when sliding the governor gear back in. I would worry as to why it was not timed correctly and if the camshaft gear was timed correctly as well.
I would check the rocker arms were all the way up on both valves at top dead center on the compression stroke before deciding not to removing the timing gear cover/front engine gear cover.
I have a problem of trusting myself with out double checking let alone trusting someone else.
Edited by Dick L - 24 Oct 2017 at 10:12am
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 24 Oct 2017 at 11:49am
I will verify the cam timing when I pull the governor gear.  I had the valve cover off and was watching #1 intake to verify tdc and when piston is up both valves are closed but its possible to be off a tooth or 2.  When I got the tractor the governor housing was loose as if it had been removed, I suspected, to repair the throttle pivot pin/oil tube as it was loose in the housing.  so who knows!?
Gerald J. View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 24 Oct 2017 at 12:00pm
I have the AC shop manual for G, B, C, and CA on line at:
http://geraldj.networkiowa.com/Trees/Allis-Chalmers-G-B-C-CA-Service.pdf
It is much better than the simplified I&T manual.
I also have a magneto shop manual there:
http://www.geraldj.networkiowa.com/Trees/FM-Xmagneto.pdf
Gerald J.
TomMN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomMN Quote  Post ReplyReply Direct Link To This Post Posted: 25 Oct 2017 at 8:23am
TDC can be found by looking at the set screw on the front crankshaft pulley.  the keyway from the factory lines up with the crank journals.  On a B, C, CA you'll see it pointing pointing straight up when 1 and 4 pistons are at TDC and straight down when pistons 2 and 3 are at TDC.  The other way on a WC, WD engine.  I might be remembering this backwards but as you are turning the crankshaft it is easy to follow it.  As air is pushing out from the spark plug hole on number one, start looking at the set-screw and continue turning until it is vertical whether it is down or up.  Of course if someone has welded up the crankshaft and machined a new keyway all this goes out the window but I have never seen one not lined up.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 25 Oct 2017 at 10:13am
Tom, I'll have to take a video of you doing that at Hutch next year.  it saved me a LOT of time and aggravation!!  OR, you could do it yourself and post it to your web site. Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 25 Oct 2017 at 10:39am
YES. Tom I got to thinking and went to your website and looked at the magneto timing.  Then did the head smack (doh).  if I would have looked in the timing gear section of my book im sure its in there but was flusterd and trying to find it in the electrical/ignition section lol
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 25 Oct 2017 at 11:36am
Didja gitter goin??
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 25 Oct 2017 at 11:43am
not yet, between harvesting and family stuff havnt had a chance to work on it.  mom and kids will be gone a couple days end of this week so ill have time then.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 27 Oct 2017 at 8:26am
Ok guys.  lined up the governor gear and slapped the mag back on last night and purred like a kitten.  (Like the V8 commercial, slaps forehead).  Assuming the PO knew what he was doing cost me a lot of time.  you never know what you will get into with these old tractors.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 27 Oct 2017 at 11:18am
Good Deal!
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomMN Quote  Post ReplyReply Direct Link To This Post Posted: 27 Oct 2017 at 2:42pm
Glad to hear you got it figured out.  I really like the pictures Dick L has of the timing gears and the mag-drive slot all lined up like that.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill Long Quote  Post ReplyReply Direct Link To This Post Posted: 27 Oct 2017 at 3:01pm
Congratulations!!! Glad to see another AC back to life.
Good Luck!
Bill Long
