AC 7060 pulling tractor for sale
mbachmojave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mbachmojave Quote  Post ReplyReply Direct Link To This Post Topic: AC 7060 pulling tractor for sale
    Posted: 22 Oct 2017 at 5:32pm
1975 AC 7060 tractor set up for pulling, was at dealer power director, and torque limiter replaced and updated, engine tune up done, dyno tested at 182 on pto, everything working as it should, used for round baling, then turned into full time puller. Can pull 10,000 lbs class with 200 lbs driver and full tank of fuel. Has had lots of weight removed, still has working pto, dual hydraulics, diff lock, trans, power director, power steering, and most everything else. Has very good 20.8 r 38 r23 firestone tires, 18" 9 bolt rims, larger rotary injection pump, larger fuel injectors, large fuss fuel pump, larger turbo, and some other engine mods. Has adjustable draw bar hitch, and 6 separate weight brackets, set up for original AC weights, can hold 20, 95 lbs weights.   This tractor is ready to pull, needs nothing can be used the way it is, runs very well in farm stock classes, 10k or 10500, have run in 11k and up too. I have most of a second 7060 parts tractor as well and weights for sale as well.
Asking $13500 for tractor
Price is negotiable, I am open to offers or possible trades.
Located in central Wisconsin,
Delivery may be avalible.
Call or email for more details
715-581-9233 Mike
Edited by mbachmojave - 19 Nov 2017 at 8:47am
Post Options Post Options   Thanks (0) Thanks(0)   Quote mbachmojave Quote  Post ReplyReply Direct Link To This Post Posted: 22 Oct 2017 at 5:34pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote mbachmojave Quote  Post ReplyReply Direct Link To This Post Posted: 22 Oct 2017 at 5:37pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote mbachmojave Quote  Post ReplyReply Direct Link To This Post Posted: 22 Oct 2017 at 5:42pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote mbachmojave Quote  Post ReplyReply Direct Link To This Post Posted: 22 Oct 2017 at 5:45pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote mbachmojave Quote  Post ReplyReply Direct Link To This Post Posted: 19 Nov 2017 at 8:48am
Price updated for tractor, need to make some room in shed.
