WD45 Control Fork, need part or help
Penny220 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Penny220 Quote  Post ReplyReply Direct Link To This Post Topic: WD45 Control Fork, need part or help
    Posted: 21 Oct 2017 at 8:10am
According to the manual the part we are looking for is the control fork.  It's where the draw bar attaches under the tractor.  Does anyone know where we can find the part?  Steiner says it's a salvage part only.  OR...what other options do we have?  Without it, the tractor is about useless.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 21 Oct 2017 at 9:03am
If it is the fork under the belly that the drawbar pulls from and is connected to the big coil spring, that would be a salvage only. I've never seen one broken. There will be THOUSANDS of them in salvage yards around the country.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matt (Jordan,MN) Quote  Post ReplyReply Direct Link To This Post Posted: 21 Oct 2017 at 2:18pm
I have 1 new and a few used. Send me a PM. Thanks matt
Owner of Matt Scott LLC
http://www.mattscottllc.com/
Lon(MN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lon(MN) Quote  Post ReplyReply Direct Link To This Post Posted: 22 Oct 2017 at 7:16am
If Matt can't help you, I have used. But I would go with the new one as there is wear in the hitch pin and also the pin that works the hydraulic pump for the traction boosted is sometimes broken.
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 22 Oct 2017 at 7:36am
According to the Allis Parts Catalog, that Fork is the same for both WD and WD-45.
Gary
