R62 lateral tilt need help
charlesbendal View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote charlesbendal Quote  Post ReplyReply Direct Link To This Post Topic: R62 lateral tilt need help
    Posted: 19 Oct 2017 at 7:29pm
We have an R62 with an 800 head and single point hookup. The lateral tilt is not working if you press the button to turn it on the light to show it is on does nothing. If you calibrate the lateral tilt the light flashes on so the bulb is ok. I have both the box with the buttons and the box for under the console from my old combine and if I put those in it acts the same. What does the light not lighting mean?
victoryallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote victoryallis Quote  Post ReplyReply Direct Link To This Post Posted: 19 Oct 2017 at 9:23pm
Does it run off potentiometers? If so if you manipulate them does the resistance change?
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 19 Oct 2017 at 10:25pm
check the potentiometers - from min to max they need to feed back 1.5 to 4.5 volts - out of range it will not recognize it - does the auto hhc work w/o the lateral tilt? does that light come on and flash ? regular to showing error code/?   i.e. 1 the 3 flashes for a 13 error code?
This page was generated in 0.793 seconds.
