190 XT SERIES 3 smoking problem
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Topic: 190 XT SERIES 3 smoking problem
    Posted: 25 Jun 2010 at 4:47pm
I,m working on an AC 190 xt series 3 , it seems to have alot of uuummmppphhh , but the thing smokes like a train !!! It has boost out of the intake , seems to run good , idles fine , but it seems like its the fuel imput maybe out of wack ; all the ones I,ve ever had that had bad injectors all ran rough , but this one runs fine; whats some ideas? I,m thinking injectors ???
Joe(TX) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(TX) Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jun 2010 at 5:41pm
It sounds like the pump has been turned up a bunch.
Amos View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Amos Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jun 2010 at 10:45pm
Check air filter.  I had one that was plugged so solid I filled it with gasoline, went to house and had lunch, came back and the outside of the paper element was not even damp yet.  Smoked a lot less when I put a new one in.  Could also be your injection pump out of calibration.  Air filter is most likely a lot less expensive solution.
Mark D. View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mark D. Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jun 2010 at 4:50am
Our XT, 7030, and 7580's were always smokers.  The XT was turned up a bit as well.  There may be nothing wrong at all.  Its hard to tell cause too much smoke is always a matter of opinion.  No matter what, it wont run looking like its got pollution crap all over in it!!  Good luck!
Miss Behavin - D21 Super Farm
Xcessive Tinkering - 190 XT Hot Farm Puller
Watch on YouTube - http://www.youtube.com/watch?v=J2TX1Af7aoA
wayne3 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wayne3 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jun 2010 at 5:57am
 You didn't mention color of exhaust. Could make difference in trouble shooting. I'm assuming its black. Is always same color idling,cold-operating temperature, full throttle or under load?
