Allis Match plow
exroofer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote exroofer Quote  Post ReplyReply Direct Link To This Post Topic: Allis Match plow
    Posted: 25 Jun 2010 at 12:48pm
   Hi all. I posted this question once years ago and never did recieve an answer one way or the other.  For a lot of years when I was younger I competed in the local plowing matches using a Kvernelands plow. I wanted to know if Allis ever made a "match" special or competition type plow with snap coupler style hitch.  We had one for our D-15 but it had only normal moldboard set up . The plow control with this style of 3 point hitch would have made for an awesome match plow, if there was such a thing. Anyone know if such ever existed?
ToddSin NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ToddSin NY Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jun 2010 at 3:24pm
I never heard of one.
BrettPhillips View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrettPhillips Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jun 2010 at 8:23pm
If you are referring to a SC plow that used European style bottoms, I have never seen or heard of such an animal. I agree that the control capabilities of the Traction Booster system would likely open some eyes at a European style plowing match.  Would there be other differences in the plow design beside the style of bottoms?  More quick-adjust features?
Post Options Post Options   Thanks (0) Thanks(0)   Quote exroofer Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jun 2010 at 10:00pm
   I always thought being able to twist the entire plow with the wheel combined with the two over size ground wheels our three furrow had ( one land wheel and one furrow wheel) would make things like opening splits and tough finishes a lot easier. But our allis plow had corn boards on it.  Short with lots of twist. Great for breaking up clay soil (which we had) , but not so hot for laying a nice sod furrow. Always had lots of traction with the hitch point being so low and forward. A square cross shaft kit and it would make an awesome match plow.  But I don't think any such animal ever existed. Never know though, some one might come up with a picture of one some day.
Ploughman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ploughman Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jun 2010 at 8:24pm
I picked up a manual on ebay for a model 62 and 63 plow with a frame thats adjustable from 10 to 12 inches.  It also depicts the no. 340 bottom which looks like a european style bottom.  That may be as close to a match plow as you're gonna get.  I've thought about making a SC plow into a contest plow but it may not be worth the trouble.  First it will do atrocious ins and outs unless you replace the beaming crank with something like a collapsible top link or a hydraulic cylinder.  And, I would use a depth wheel and not use the traction booster to set depth to maintain a more constant depth, and this would just throw away the advantages of the SC/traction booster system.  And, like you said, modifications to the cross shaft would have to be made also.  That's what I know.
norm [ind] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote norm [ind] Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jun 2010 at 8:37pm
  talk to some of the older so called blockman[as they were called]  were only a few companies would compete because ac or massey would always win so the other ones would not compete in variuos contests  was told this by a blockman  picking corn ploughing to name a couple
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrettPhillips Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jun 2010 at 9:08pm
Please forgive my semi-ignorance of competitive plowing.  I understand the reference to using a collapsible top link or a hydraulic cylinder to improve entrance and exit distance, but I am not sure of what is provided by the addition of a square cross shaft?
Post Options Post Options   Thanks (0) Thanks(0)   Quote exroofer Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jun 2010 at 9:28am
   A square cross shaft set -up lets you use a hydraulic cylinder to adjust front furrow width on the fly and in small increments as opposed to rotating the cross shaft by lever .  Normal cross shaft has offset ends, a sliding one has the ends on center. Probably be able to see a picture of it on a Kvernelands site or other make of competition plow.
   Oh and thanks all for replies.
  I would agree with the poster who noted that a modified sysytem for plow pitch would be needed to keep ins and outs under control.
This page was generated in 0.119 seconds.
