HD5-B at tractor pull
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Topic: HD5-B at tractor pull
    Posted: 12 Oct 2017 at 8:36am
All them guys with them high HP and souped up engines and a little 48 HP Detroit just walks a sled out of the arena .
[TUBE]oaMOcWiRHRk[/TUBE]
dadsdozerhd5b View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dadsdozerhd5b Quote  Post ReplyReply Direct Link To This Post Posted: 12 Oct 2017 at 7:14pm
Awesome! I always wanted to see what my HD5B would do against the sled. Maybe someday! thanks for the video Coke.
darrel in ND View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 12 Oct 2017 at 8:47pm
that was awesome! Darrel
Calvin Schmidt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 13 Oct 2017 at 5:27am
I also pulled a sled up to the fence with my H-3 at a John Deere club show crawler pull.
The little JD crawlers were not even close. Our local JD club invites another brand as a guest each year.
ACcrazy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACcrazy Quote  Post ReplyReply Direct Link To This Post Posted: 13 Oct 2017 at 8:13am
Just takin' a little stroll. lol. Nice! Smile
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 13 Oct 2017 at 6:12pm
He prolly coulda turned around, and dragged it all the way back to the starting line...Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 13 Oct 2017 at 7:35pm
Very nice pull! Thanks for posting!
ac_sd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac_sd Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jan 2018 at 7:08pm
Love it... HD-5's Rule !!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jan 2018 at 7:44pm
Did they invite you back Calvin
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2018 at 10:08am
thats brent rupp he lives about twenty miles from me he said thats what they done all there plowing with when he was young
pinball View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote pinball Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2018 at 3:00pm
I remember years ago I went to a pull at the fair grounds in springfield Illinois with my father in law. They had several classes. they used a white tractor to pull the sled back. I think the white tractors maybe had just came out. Anyway in the big class the 2nd place guy had 3 327 motors in line. the 1st place guy had a jet engine and I think 250 was his pull. Right after that the announcer said they had one more pull. They hooked the sled up to that white tractor and it was just idling when it went though the 300 foot marker. a lot of people were surprised. that's a good video of the h5.
DaveKamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2018 at 9:44pm
Well... I'm certain it feels good to cheer on the 'little guy', but agricultural traction prediction in soil is fairly accurate:
The more weight you have on driven wheels, the less you have on undriven wheels, the diameter of the wheels (when round) the contact surface area of the wheels or traces... all have a very obvious effect of drawbar tractive effort.
Your 'big boy' hot rods are what... 6,000lb weight class or thereabouts. At a 33% slip rate, you're only gonna get 1980lbs of pull when the tire starts to slip.
Compare that to an 11000lb tracked machine's capacity (11,000*.33) of 3630... of COURSE it'll win. Now put in mind that the tracked drive, as a virtue of it's tracks, will have a higher percentage of tractive effort, it's a rather big shoe-in...
Ian Beale View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ian Beale Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2018 at 11:49pm
Maybe a different set of rules for crawlers
British Test Report No. BS/NIAE/56/6 IH BTD 6
5 speed manual transmission
Total weight  12859 lb
Max drawbar pull  10500 lb (1st gear)   Slip  4.8 %
Max sustained pull (1st gear) 11700 lb.  Limitation - engine stall
Edited by Ian Beale - 16 Jan 2018 at 11:50pm
talntedmrgreen View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote talntedmrgreen Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jan 2018 at 8:23am
Fun to watch Clap
Patterson B1*B1/B1Forklift*B10*BigTen/B1Loader*B110*B208*B206*616*Homelite T16H/T8/T7/RM7E*Landlord/Loader/Trencher*Broadmoor717*Serf525*2110*7790*Legacy XL*Twin 20*Squire9*Squire6*JCPenny 494
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jan 2018 at 9:51am
Power to weight ratio - as said on tires - where the rubber meets the road .
I do know a HD5G will not bull a fully loaded 12 yard concrete mix truck out of a soft spot when the tandem set is rim deep is soft stuff .  ( but it will spin the tracks )
jerbob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jerbob Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jan 2018 at 12:54pm
Sounds like first hand experience Coke.
