hydraulic stop leak
DanC911 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanC911 Quote  Post ReplyReply Direct Link To This Post Topic: hydraulic stop leak
    Posted: 09 Oct 2017 at 10:19am
Has anyone used a hydraulic stop leak additive?
I have been chasing a hydraulic leak in my WD for a while.  I had the pump and PTO gearbox rebuild and that slowed it somewhat.  I thought it was the connection for the rear remote so I plugged that but no luck.  It has all new hoses and fittings.
It is more than an in inconvenience and bordering on annoying.  I think it is why the lift arms drift if I leave them up but it leaks when they are down too.  The hold valve is dry and went to Sandy Lake on the pump when I sent it out.
I ordered some dye to see if I can find it and saw the stop leak and thought I would ask for opinions.  I am leery of quick fixes because they tend to hide a bigger problem.
Post Options Post Options   Thanks (1) Thanks(1)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 09 Oct 2017 at 11:13am
I would NEVER use a 'stop leak' product for hydraulics. It is NOT necessary if you totally go through the ENTIRE system.
When you say 'it leaks'. WHERE does it leak? Where does it dribble out from ?
I'm not a WD guy, know the pumps are different from the D-14s, but hydraulics is hydraulics...
reservoir,pump,hoses, rams....
I know you need to clean 100% of the system at the same time otherwise a speck of crud can 'float' around the system, that's where extra eyeballs help, strong lights and lots of 'flushing'( maybe 5-7 times).
Need more information and I KNOW there's a LOT od WD guys here that can help.
Joe(TX) View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote Joe(TX) Quote  Post ReplyReply Direct Link To This Post Posted: 09 Oct 2017 at 11:21am
Have you tried rebuilding the lift cylinders?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanC911 Quote  Post ReplyReply Direct Link To This Post Posted: 09 Oct 2017 at 11:26am
The drip is coming off the drain plug on the bottom of the valve on the pump.  (Not my pump, I borrowed a pic online.  I think it's Sugarmaker's.)  It is tight but I don't see any thread sealant on it and I don't think it is coming from there anyway.  It is just the low point that it is dripping off.
The left side is moist about half way down so I think it is coming from above but I do not see any drips.  That's why I am going to try the dye.
Edited by DanC911 - 09 Oct 2017 at 11:27am
Stan IL&TN View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote Stan IL&TN Quote  Post ReplyReply Direct Link To This Post Posted: 09 Oct 2017 at 11:27am
You need to give the old girl a good bath to clean away the crud so you can see where the leak is coming from.  That would be my first step.
1957 WD45 dad's first AC
1968 one-seventy
1956 F40 Ferguson
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanC911 Quote  Post ReplyReply Direct Link To This Post Posted: 09 Oct 2017 at 11:28am
Bought rebuilt cylinders from a site member and replaced all of the hoses and fittings.
Bill Long View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote Bill Long Quote  Post ReplyReply Direct Link To This Post Posted: 09 Oct 2017 at 12:18pm
You may want to remove the plug and check to be certain the threads on the plug match the threads on the pump housing.
We did this once with a B oil pan.  It was leaking so we put in a pipe plug.  Bad idea.  Wrong threads and leaked.
Drained the oil.  Re-did  the threads with a proper tap.  Put in plug with matching threads and sealed with number one permatex (that is what we used in the 50's - I am certain there is better now)
Worked!
Hope this may help.
Good Luck!
Bill Long
CrestonM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 09 Oct 2017 at 12:35pm
Yep! From my experiences, cleaning a tractor is a sure-fire way to find leaks and resuscitate old ones. Lol
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanC911 Quote  Post ReplyReply Direct Link To This Post Posted: 09 Oct 2017 at 12:42pm
That is why I am hesitant to pressure wash it.
Allis dave View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 09 Oct 2017 at 12:53pm
Agree with everyone. Need to find where it's leaking.
COuld be several places
gasket between the pump and torque tube. It's difficult to install the pump and not damage the gasket.
oring between hold valve and pump.
lines going into the hold valve.
These are the mostly likely if Sandy lake rebuilt it. My money is on the pump to torque tube gasket
darrel in ND View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 09 Oct 2017 at 1:06pm
I wouldn't shy away from trying some lucas hydraulic booster in it. Darre
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanC911 Quote  Post ReplyReply Direct Link To This Post Posted: 09 Oct 2017 at 1:33pm
So you would try it?  Have you used it before?  What was your experience?
m16ty View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote m16ty Quote  Post ReplyReply Direct Link To This Post Posted: 09 Oct 2017 at 5:52pm
You're just going to have to clean the area and dry it really well and trace where it's coming from. If you develop new leaks from cleaning it, they needed addressing anyway so I wouldn't worry about that.
Ed (Ont) View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote Ed (Ont) Quote  Post ReplyReply Direct Link To This Post Posted: 09 Oct 2017 at 7:27pm
Some dye in the system is a good way to go. Do you have uv light and the glasses to go with it? Clean everything before you start. Run it a bit and start looking - indoors if at all possible. Very hard to see anything outside.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanC911 Quote  Post ReplyReply Direct Link To This Post Posted: 09 Oct 2017 at 8:49pm
I have the dye on order and the light and glasses from some UV adhesive I used to make redneck wine glasses from mason jars and candlesticks.  They were a hit as Christmas gifts full of candy but I digress.
HD6GTOM View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote HD6GTOM Quote  Post ReplyReply Direct Link To This Post Posted: 09 Oct 2017 at 8:55pm
Dan I have a hydra Mac skid loader that has o rings in blocks to seal the hydraulics. The Hydra Mac dealer told me they always leak. My hydraulic system holds somewhere between 20--30 gallon of oil. I put a gallon of Lucas hydraulic stop leak in the system Once a year. It slows the leaking down to where it is tolerable. I was apprehensive about using it, I use the loader in the winter to feed hay, wondered if it would plug filters. Hasn't adversely effected anything, need to put in another gallon soon.
B26240 View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote B26240 Quote  Post ReplyReply Direct Link To This Post Posted: 10 Oct 2017 at 6:11am
The way I do it is as follows, clean area of dirt and grease then spray starting fluid on it and blow dry with compressed air. Leak will be easy to see with good lite. I have never used stop leak and see it as "snake oil".
Post Options Post Options   Thanks (1) Thanks(1)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 10 Oct 2017 at 8:30am
I agree with Allis dave, more than likely it's the gasket at the torque tube.
CAREFULLY try to tighten the bolts that hold the pump on.  They COULD be loose, I've had it happen.  And if someone pulled the pump and did some work on it, I'd bet money that the gasket got torn when putting it back in.  It's VERY EASY TO DO, tear the gasket.
CaseyCreek View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote CaseyCreek Quote  Post ReplyReply Direct Link To This Post Posted: 11 Oct 2017 at 2:15pm
I have used Blue Devil stop leak in my Ford 7700 steering arm.  Worked pretty well.  I had just spent 180 dollars having it rebuilt and it leaked again almost as soon as I installed it.  I threw some Blue Devil in it (about three ounces).  So far, I prefer it to the hydraulic shop that rebuilt the cylinder.
On pretty much everything else, I agree that avoiding the miracle cure section of the auto parts store is a good rule of thumb.
D17 Series III,D17 Series IV, 185
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanC911 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Oct 2017 at 9:55pm
I put some UV dye in the hydraulic fluid and saw a leak from the hand clutch cover.  So I took off the battery box and the cover to find no gasket and what looks like silicone calk.  Just translucent or clear caulk.
I made a gasket put it back together and started looking for other leaks.
This is the leak I have been chasing.  Leaking from the bold on the right and dripping off the drain plug on the bottom of the pump.  Lights up like a neon sign under UV light.  I couldn't have found this one without the dye.
Any suggestions for an easy fix?  I really don't want to pull the pump again.  Hytran is getting expensive!!
Post Options Post Options   Thanks (1) Thanks(1)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 12 Oct 2017 at 10:40pm
If the gasket behind that right bolt head was installed without any sealer or goo, it will probably leak.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanC911 Quote  Post ReplyReply Direct Link To This Post Posted: 16 Oct 2017 at 12:54pm
Thanks Dr. Allis, That may be the problem.
I think I have a temporary fix by using some thread sealant on the bolt and a fuel resistant o-ring behind the bolt.  Leak seams to have stopped for now.  Let's see what happens when I run it doing firewood this weekend.
This page was generated in 0.104 seconds.
