Where to buy D-14 wheels?
baverwolf View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote baverwolf Quote  Post ReplyReply Direct Link To This Post Topic: Where to buy D-14 wheels?
    Posted: 24 Jun 2010 at 9:13pm
My D-14's wheels have finally decided they've had enough. I think there's been a few slow leaks over the years in the tubes and the chloride has ate them up pretty bad. I want to buy some new ones. Where should a guy look? Where's the best buy? Maybe someone has some new ones they don't need? Let me know what you think!
Thanks!
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jun 2010 at 9:31pm
I got new ones from Moore Tire in Rockfalls Illinois. See the link. They had spin out rims on hand and were $100 cheaper than Steiner tractor.
http://www.mooretires.com/wheels.html
bigfish_Oh View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bigfish_Oh Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jun 2010 at 11:22pm
location, location, location, profile please
1941 WC sat for 29 years,started & dynoed 27 h.p.
1957 WD45 Grandpa bought new,factory p.s.,added wfe
1951 WD, factory p.s.
1960 D14 HnMk IV BkHoe 4 sale
2014 HD Tri Glide
2009 GMC CC SLT Dually
GregLawlerMinn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GregLawlerMinn Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jun 2010 at 9:48am
13.6X26" tires are hard to come by around here; and expensive when found. My D15 had bad rear tires, I found a decent pair of 16.9X26 tires on combine rims at a nearby salvage yard; my rims were still good, so I swapped the tires unto my rims. Since the front tires were on the down side, and I have a loader on the tractor, I purchased new (larger) rims and 6.50X16 front tires at the same time. The tractor looks "tough" with the bigger tires and I am satisfied with how well it performs.
A few folks around here have converted their D14s and D15s over to 28" tires and rims from a WD or WD45. The rims/centers from a WD or WD45 bolt right on. They tell me that it does not noticeably affect the tractor's perfomance and they do not look "out of place" either.
JimD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JimD Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jun 2010 at 11:14am
We have new 12x26 spin out rims for $255.
JIm D
877-378-6543
Post Options Post Options   Thanks (0) Thanks(0)   Quote baverwolf Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jun 2010 at 2:21pm
I updated my profile with location. Also, has anyone put 14.9 26 tires on they're D14? How much taller are they?
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jun 2010 at 4:53pm
I would think 14.9-26's might have been an option or should have been.
R Aiken View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote R Aiken Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jun 2010 at 6:42pm
Here is a comparison of 13.6 X 26 on my D14, and 14.9 X26 or 13.6 X26 combine wheels and tires.  The 14.9 are 5" taller .
Post Options Post Options   Thanks (0) Thanks(0)   Quote bigfish_Oh Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jun 2010 at 6:45pm
Here are some on my backhoe, I am going to drill more fenders holes to move fenders in so I can have more clearance. It just fits between fenders. They do make a D14 look smaller !!   I will keep 13's on the other 14.
2014 HD Tri Glide
Post Options Post Options   Thanks (0) Thanks(0)   Quote baverwolf Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jun 2010 at 10:41pm
Wow, I didn't realize they'd be about 5" taller!  Wonder how much it will affect the gearing?? I wouldn't mind if it was a little taller geared. This tractor will still be a part time worker. I use it with a rotary mower, belly mount sickle mower, and I have a small cultivator I'm going to start using to farm between my windbreak rows once I get new tires and rims.
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jun 2010 at 12:21am
My 58 D14 came with 14.9x 26 (option) and my 59 has 13.6.  Doesn't look like there is much difference, but have not had them side by side yet for comparison.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jun 2010 at 12:31am
5 inches taller ought to really speed it up on the road. I don't know about new tires, but used 26's are plentiful in Colfax Tractor Parts' yard.
Jack(Ky) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jack(Ky) Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jun 2010 at 6:29am
I have 14.9's on my D14 and I think they look better than the 13.6 that came out on it. They are probably no more than a couple inches difference.JP
