wc head
Daniels wc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Daniels wc Quote  Post ReplyReply Direct Link To This Post Topic: wc head
    Posted: 02 Oct 2017 at 12:44pm
I have water in my oil of my WC and and low on radiator fluid and had drove it about a mile and them was going to change oil in it and when it got to where I was going it was really warm and you can see some liquid coming form betwine the head and the block and wonder what it was for sure and how hard it might be to fix thanks
HoughMade View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HoughMade Quote  Post ReplyReply Direct Link To This Post Posted: 02 Oct 2017 at 3:21pm
Hopefully its just a head gasket.  Not a horrible job.  There are other possibilities, but checking out any of them will mean pulling the head anyway, so start there.  Spray some penetrating oil on all the fasteners (especially the manifold) and soak for a couple of days if possible, strip everything off of the head, pull the valve cover and remove the pushrods (mark what position they came from, 1-8 so they can go back).  When you get the head off, hopefully you will find an obvious break in the gasket.  If not, there are other things to explore, but we can cross that bridge when we come to it.
Good luck!
Edited by HoughMade - 02 Oct 2017 at 3:22pm
Driverdan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Driverdan Quote  Post ReplyReply Direct Link To This Post Posted: 02 Oct 2017 at 3:51pm
Had similar problem with my WC. Ran it for a few minutes with valve cover off, and watched coolant seep up through rusted freeze plug and run down push rod galley. Replaced freeze plug and never had to pull head. Hope that helps... Dan
